Pro Tools 2021 supported on High Sierra?
I have a Mac Pro cheese grater 4,1 that I flashed to 5,1, with a clean install of High Sierra on it. I am about to buy an HDX card. But unless I'm mistaken, I am not seeing High Sierra supported for Pro Tools 2021. Is that correct? I think High Sierra is the highest I can go on this machine without upgrading graphics cards? I'm new to the whole subscription plan, but if I sign up for the Ultimate Plan, is my only option to get the lates 2021 release? Thanks for the info! |
Re: Pro Tools 2021 supported on High Sierra?
To be honest, I think you would benefit greatly to upgrade your GPU anyway, so whether you use HS with older PT or Mojave with latest PT you would enjoy that new card.
I have one of those old 2009 macpro4,1 and at that time GPU's were weak.
It installs and works just fine. 10.13.6 on a 5,1 12-core 3.46GHz.
You can also install Mojave without upgrading your graphics card. http://dosdude1.com/software.html Install a new SSD, partition it, and experiment so that you can go back and forth between macOS/PT versions. |
So, just to clarify, you're saying that Pro Tools 2021 installs and works just fine on High Sierra, without upgrading to Mojave? And without the Metal compatible upgraded GPU? |
Works totally fine in High Sierra.
Wasn't "officially" tested with this version by Avid -- when they add a macOS (Big Sur), they drop a macOS (High Sierra) so they don't have to test too many platforms. You can see my system stats below.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
yes.
Is Pro Tools 2018 EVER going to be supported on a current Version of High Sierra? | off the wall | macOS | 10 | 01-05-2019 04:53 PM |
Pro Tools on High Sierra | adam79 | macOS | 2 | 04-13-2018 05:52 AM |
Why are Avid Interfaces Not supported on High Sierra ? | K Roche | Pro Tools 12 | 5 | 12-20-2017 04:37 PM |
macOS High Sierra 10.13 not yet supported | Avid | Technical Alerts | 0 | 09-25-2017 11:29 AM |
macOS Sierra 10.12 now supported with Pro Tools v12.6 | Avid | Technical Alerts | 0 | 10-26-2016 12:29 PM |
