Mac mini 2018, PT 12.4 and mac mini
Hi all,
I'm having a hard time, due to having to go to multiple sources, to see if my Rack 003+ will work with the mac mini 2018 specs below; Apple Mac Mini 3.2ghz 6-core Intel i7 16gb-64gb 128gb-2tb SSD New 2018 Model, OS Catalina. I'm currently running PT12.4 in mac pro 3,1, OS el capitan, and I want to keep the 003.
Hello there. |
Catalina? Definitely not.
Mojave? Maybe. I didn’t have any luck on the same machine, but YMMV. Personally, I’d be looking at moving away from that interface if you can. BTW - PT12.4 won’t run on Catalina either. Sent from my iPhone using Tapatalk |
Re: Mac mini 2018, PT 12.4 and mac mini
Thanks.. I'm just trying to figure out if I should get a mac pro 5,1 or go to a mac mini.
Hello there. |
Don't get suckered into sunk cost fallacy, that for example that just because you own an old interface that you should keep planning around that. Interfaces have improved since the day of the 003. You may be better off getting onto a modern interface, modern version of Pro Tools and current computer. Do you need to stay on Pro Tools 12? To finish projects? For exact compatibility with other users? Pro Tools has also moved on a lot, significant CPU stability improvements in 2019 (I could never see going back before those improvements), disk cache in 12.6 and later, etc. |
Hello there. |
You can buy a Mini, try it and return it within 14 days if it doesn’t work.
But, 003 drivers are unsupported past Sierra. Like I said, it did not work for me when I tried it on a client’s machine. I understand not wanting to spend money, but if your machine really is your bottleneck, then you may have no choice. Sent from my iPhone using Tapatalk |
Hello there. |
But you can’t run High Sierra on the 2018 Mac Mini, so that’s of no use. Mojave or higher. Honestly, if you really want a new machine, you’re going to have to seriously look at a new interface. There’s plenty of good and also inexpensive 8 i/o interfaces on the market these days. Heck, if you really wanted to keep running the 003R, you could get a really cheap new interface with ADAT ports and connect it that way. Either way, a new computer purchase is going to require an update to BOTH your hardware and software. Sent from my iPhone using Tapatalk |
MAC Mini 2018 with eGPU | 11miles | Pro Tools 12 | 0 | 12-18-2019 12:45 AM |
Mac Mini 2018 & PT... | Boe Larsen | Pro Tools 2019 | 14 | 11-18-2019 03:21 AM |
2018 Mac Mini 6 Core i7 | Siegfried Meier | Pro Tools 2019 | 47 | 10-02-2019 10:50 PM |
Can I run 10 and 2018 on new Mac Mini? | Adupr | Pro Tools HDX & HD Native Systems (Mac) | 10 | 03-03-2019 02:15 AM |
HDX with 2018 Mac Mini | A Chapman | Pro Tools HDX & HD Native Systems (Mac) | 5 | 01-17-2019 09:35 AM |
