Old 09-10-2019, 06:32 PM
anguswoodhead's Avatar
anguswoodhead anguswoodhead is offline
Default HDX - CPU Errors - really????
Installed my newly refurbished HDX card last night
Still getting the dreaded CPU error / stop
This is doing my head in.
It's only a small session too.....
Any help appreciated.
https://www.glasshousestudios.com.au
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
Pro Tools Ultimate 2023.12
HDX card
AVID TB3 1 slot PCie Chassis
Old 09-10-2019, 06:33 PM
Default Re: HDX - CPU Errors - really????
my Mac Pro specs....
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
Old 09-10-2019, 06:46 PM
BScout BScout is offline
I'd look at:
Antelope Audio Orion 32 HD
as your issue. Do you have another hardware interface to connect?
Old 09-10-2019, 10:08 PM
YYR123's Avatar
YYR123 YYR123 is offline
So I would trash prefs and create a new session to see if the problem follows
If it does, then I would look at plugs as culprits....
If removing them doesn’t fix it, then I would check my drivers for everything
Daniel
Old 09-11-2019, 01:40 AM
clivvy clivvy is offline
this has been an on going problem in HD native also is Avid going to take care of this we are all paying customers we demand a fix!
Old 09-11-2019, 03:36 AM
JFreak's Avatar
JFreak JFreak is offline
I don't have this problem on my Apogee Symphony II no matter if I connect it via HDN or TB.
So as said, the problem is likely -- as the error msg says -- in clocking. In other words the interface. It may be simply cable going bad or something more serious, but if it doesn't happen everywhere and especially when you use 3rd party interface, you really cannot put the blame on Avid until you have gone through troubleshooting everything else.
Also 2009 model Mac Pro that says 5,1 means you have flashed it to 2010 model, which means your computer isn't in factory specs any longer. It may or may not contribute to the problem.
And finally; is there a reason you aren't running 2019.5 which reportedly works wonderfully? You should at least try whether it fixes your problem.
Janne
Old 09-18-2019, 09:05 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
I have the problem on most of our systems... 3-HD Native and 1-HDX2. I purposefully have to open a new session and record 'nothing' on any track until I get the error. Once that happens, I'm good to go as long as I don't quit the app.
Been this way for quite a while.
BTW, our HDX-2 system is a MacPro Tower 2x2.4GHz 6-core with 40GB RAM. All IO on that system is via MADI from an SSL C200 console using SSL's MADI X-8 router. This system is in an HD Video truck and has had it's share of issues with 128-channels of IO, but we have a great backup recording system using two JoeCo 64-channel MADI recorders. Brainless... and they've saved me multiple times. Too bad we have to pay such 'fees' to Avid and still use something else as a backup.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 12-19-2019, 08:30 PM
Thanks for your thoughts.
A high end engineer I trust recommended High Sierra and 2018.12 as a stable combo.
What should I be using in your opinion please?
I do have a current subscription.
I need OSX (I do not have a metal video card) and PT version that will run best together.
Thanks in advance.
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
Old 12-19-2019, 09:03 PM
JFreak's Avatar
People have been reporting very good Mojave experience after upgrading GPU
Janne
Old 12-19-2019, 09:04 PM
High Sierra + 2019.6
Errors when recording MIDI piano, no errors during playback calebgilbreath Pro Tools 12 2 12-07-2017 11:12 PM
many errors- fatal errors and 9060 error. Sandra report inlcuded.. bradykrzemien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 09-16-2009 11:56 AM
Creating DAE Objects/DAE Loaded!! errors errors HELP!!!!! KasticK Pro Tools M-Powered (Mac) 2 10-20-2007 10:42 AM
HW Buffer errors and Mass Confusion! 9093 Errors!! guitarlancer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-08-2007 10:38 AM
errors errors errors Please digi tech guys help me dunkyj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-11-2005 01:19 PM
