Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 05-31-2019, 03:29 PM
aftermid aftermid is offline
Default Midas M32 as Control Surface
I just purchased a Midas M32 Live console. The board has some DAW control, but from what I can see it only controls the faders on ProTools. If I move a fader on the M32 or PT, they mirror each other fine. But that seems to be the only thing you can control. I tried something simple, like panning, and their is no response in either direction from M32 and PT. Has anyone been able to set these basic motor functions to respond on PT with a Midas M32?
Old 06-03-2019, 03:28 PM
albee1952 albee1952 is online now
Default Re: Midas M32 as Control Surface
Its only going to have basic HUI function(and IIRC, only the 8 faders in the master section will work). Have you set up in Peripherals?
Old 06-03-2019, 10:26 PM
Yeah, Peripherals have been set up. It will mirror the fader moves, but not he panning. In Logic, these midi commands can be learned, but in Pro Tools, I can't get it to recognize panning from the console.
Old 06-04-2019, 09:10 AM
Hmmm, not sure but it might be a limitation of PT Express
Old 06-04-2019, 07:09 PM
Old 06-04-2019, 07:22 PM
YYR123's Avatar
YYR123 YYR123 is offline
I believed the Transport functions worked as well but that’s it
Basic HUI
Daniel
Old 06-06-2019, 09:33 PM
What's interesting is that I can get it to work in Logic. Logic has a learn function for midi commands. I can't imagine that PT doesn't have a similar way for something so basic as panning control.
Old 06-07-2019, 06:20 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Logic doesn't sell dedicated control surfaces. Avid does.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 06-07-2019, 02:44 PM
lancemcv's Avatar
lancemcv lancemcv is offline
I have the m32r and no there is no pan function ( I am mistaken as I just figured out a way to do it read below post), just mute, solo, faders, my faders are so noisy when tracking automation, it’s a shame, I think the bigger M32 is better as far as noisy faders go. There are some other functions as well. When in remote daw mode, holding down the group DCA 1-8 you can bank by group of daw channels or one track at a time you will see the scribble scripts change to bank left bank right and also There is left right up down for selective g tracks or moving left or right through your timeline. I set up the custom assign buttons 5,6,7,8 for banking as you don’t have to hold down the group button and then tap mute buttons to bank through tracks just tap them once it’s much better. Hold down bus1-8 to set a track in record ready and your mute buttons become record ready buttons, matrix Main button changes the mute buttons to transport no need to hold it down, and this one is kinda funny hit fader flip and you will see the mute buttons say “touch” all this does is light the mute button when you “touch a fader” sillypan would have been much better to have. I have not messed with midi to try and see if I can get a knob to be assigned for panning, but it’s easy enough to use the pro tools iPad app which i do in conjunction with the M32 daw remote. It’s Econ based so they work together st the same time. Great for soloing tracks as you don’t have to scroll through banks to hit solo and you CAN PAN I just figured out how to use a assign button and an encoder to be able to scrub or set to shuttle.
Mac Pro 5,1 12 core 3.46ghz
OS X 12.6.1
Opencore 0.8.6
Pro Tools Ultimate 2022.10
Mac Pro 2009 upgraded to 5,1 12 core 3.46ghz
GPU RX6800XT, Samsung 970 EVO Plus pcie boot drive, Titan Ridge flashed for Mac.
Midas M32r console. iPad Pro with Avid Control
Old 06-07-2019, 03:54 PM
lancemcv's Avatar
Ok this is crazy I just found a way to use pans. Here goes.
Hit the view button in the custom assign buttons then from the home tab switch to Set A - Select encoder 1 so its highlighted. then select target type "remote" so its highlighted then parameter 1 (that will then use encoder 1 to pan what ever track is in the position of the first channel coming up on your daw. You do this for the Set A of encoders, 1 2 3 4 which are the middle 4 encoders of the 6. Then go back to the assign view home page and select set B and set encoders 1 -4 again to 5 6 7 8.
This gives you pan control of the currently selected 8 faders! OF corse this is not the way you would really want it as you would rather hit the select button on the channel and then turn the big pan knob to pan. Even tech support said there was no way to pan so I have to give myself a pat on the back! Maybe by digging some more there is a better way than this but now we know Remote parameter 1-8 is pan for daw remote.
OS X 12.6.1
Opencore 0.8.6
Control surface : Mix + Virtual Inst control (PT12 HD) redmount Virtual Instruments 4 03-30-2016 02:42 PM
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
