Pro tools will not maximize after being minimized
I am running Pro Tools 12.2.1 on Windows 7 .
If I have Pro Tools open and I am working on a session and I minimize Pro Tools to check another program or info maybe in a folder that is on my desktop when I am done and click on the Pro Tools icon in the task bar PT will not maximize? The only way to maximize it is to push Control + Alt + Delete and then right click on PT and then choose maximize and it brings it back up. I have been using the newest version of PT for 4 months without this happening. It happened after I changed a setting in my Bios to try and see if it would help another issue I was having with my hardware and sound playback. This change did not help so I went back into the Bios and changed it back to the way it was before the change. There has to be an easy fix for this. |
Re: Pro tools will not maximize after being minimized
Read my post in the other thread you posted in. It worked for me. And after not having the minimize problem, then out of the blue having the minimize problem, now out of the blue the minimize problem has gone away.
Cheers,
Take your projects to the next level with a non-union national read at reasonable rates Demos: brucehayward dot com SonoBus Source-Connect: brucehayward Options for Remote Direction Last edited by The Weed; 10-30-2015 at 10:35 AM. |
can not maximize pro tools window??? | bleudog | Pro Tools 11 | 59 | 05-28-2018 10:07 PM |
PT1 minimized in background, can't hear audio from media players or web?? | JLiRD808 | Pro Tools | Intro Discussion | 4 | 08-29-2015 02:32 PM |
more intimate shotgun with minimized room sound VS lav | SupreGlu | Post - Surround - Video | 26 | 10-10-2012 09:38 AM |
CPU usage jumps to 100% when saving if edit window minimized | frantik | Pro Tools M-Powered (Win) | 20 | 10-25-2009 05:22 PM |
Playback Interrupted When Minimized | NonSpecific | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-18-2006 08:15 AM |
