Old 12-24-2011, 04:36 AM
Bassturbator Bassturbator is offline
Default PT10 (HD?) BUG: Select Unused Clips
ProTools sometimes won't select the unused clips in the clip bin.
VERY annoying when cleaning up you're session(s).
Workaround:
1) Create new track
2) Delete the newly created track
Then the shortcut (or selecting from the drop-down menu) works like it should.
Old 12-24-2011, 04:45 AM
Default Re: PT10 (HD?) BUG: Select Unused Clips
Update: More specifically (as it appears to be in my sessions anyway), it are the clips from the deleted unused playlists that aren't selected.
Old 12-24-2011, 10:52 PM
stevecaboose stevecaboose is offline
This was a bug that was in PT9. It looks like they still have not gotten around to fixing it.
Select unused clips - Key command not working? ronwasserman Pro Tools 11 5 06-21-2013 11:48 PM
Deleting Unused Clips ReynaldoPena Windows 3 12-02-2012 01:44 AM
Select Unused Regions Dan Pinder Tips & Tricks 2 02-13-2005 04:43 AM
Select Unused Question bickele 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-05-2002 04:46 PM
select unused will delete unused jimlongo Pro Tools TDM Systems (Mac) 4 04-04-2001 06:39 AM
