Old 10-24-2011, 02:39 PM
yosemitesam yosemitesam is offline
Default What is the thermal output/heat load of HD core cards and process cards?
We're trying to put our rig in an ISO box, and we need to make sure the heat dispersion system we're getting is powerful enough. So we're trying to figure out how much heat each of our components generate.
What is the maximum thermal output/heat load of an HD Core Card and an HD Process Card? Either BTUs per hour or watts is fine. Alternatively, if someone knows the maximum power consumption of these cards, that works too, since we'll at least know that the thermal output has to be less than the power consumption. Thanks.
Modern motherboard for original PCI HD Core and Process cards David Sandwisch Pro Tools TDM Systems (Win) 48 08-28-2011 02:19 PM
Remote access to HD Core & Process Cards though the LAN???? pmcmurt Pro Tools TDM Systems (Mac) 3 06-06-2011 11:15 AM
Motherboards and systems for use with original HD core and process cards? David Sandwisch Pro Tools TDM Systems (Win) 16 04-20-2010 06:42 PM
PCI-X G5 and HD core and process cards Charles Schaefer Pro Tools TDM Systems (Mac) 5 12-26-2005 02:23 PM
HD Core and process cards faulty??? Michel Pro Tools TDM Systems (Mac) 7 03-09-2002 04:59 AM
