Protools LE on a Imac i7
anyone using a i7 with protools LE? I have to replace my macbook pro because I need more horsepower for mixing and I was wondering if I get double power with this new setup... how about FW800 and mbox pro?
Re: Protools LE on a Imac i7
using it and loving it. Works great, no issues.
I have an 002R, not an MBox and running a Glyph GT050Q 1.5TB external FW800/400 drive.
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
what about mixing? using 4-6 reverbs 2.3 delays and eq/comp on almost every track of a 50 track session? I'm trying to find out if I get a 50% boost from my mac book pro..
peter99, I have a older intel 1.83 duo core with only 2 gigs of ram and using verb on 10 tracks plus running 32 tracks and it's flawless.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
not here.. I have a session with 50 tracks, URS channel strip pro an almost all of them and some special effects like drum parallel comp, some sans amp and I'm on 72% cpu power... not fun working like that - I guess with double power everything would be smooth...
Hmmm... wondering whether to make the transition.
I'm plagued by "DAW can't grab audio from the drives fast enough" prompts, but it only seems to be an issue when i'm pushing the CPU performance cieling of my 2.33C2D 4G RAM iMac. Got a Glyph HD, so transfer rate shouldn't be a problem. |
On my Imac I5 I can run 48 stereo tracks with over 400 instances of DVERB. The I7 should get over 500. I think most compatibility issues lie with the MBox though the I7 have had some also. If you get it, I recommend not doing a migration from your old mac. Just start fresh and create new accounts and reloaded all your software once OS X is completely updated.
Imac Pro 27" 10-core with a LG 4K for a second screen OS 10.14.4 Pro Tools 2019.6 UAD Apollo X8P With an extra 8 channel ADAT using a Focusrite Liquid Saffire 56 UAD Twin duo UAD TB3 Octo Satelite Focal Twin Be monitors samsung T5 and Gdrive |
I have an Imac I7 27" 4Go 1To
Very very great. You can Run the 48 Stereo Tracks, instruments, Plug in easy I use at the same time at 256 (Buffer) : -Superior Drummer plug in with multi out (Each parts of the drum kit in an Aux Track). -3 "Guitar Rig plug in" -Reason in Rewire. -Reverb, Delay, Compressors, multiBand.... -Expand 15% in the CPU. And I'm a bad boy, I use my internal Hard Drive
Imac 27' I7 Quad core 2,8 Ghz Snow Leopard 10.6.2 4 Go RAM 1To Protools 8.0.3 MBox 2 M-Audio Axiom 49 |
Oh yeah my brother is bigger than yours (he he). I have test session that has one audio, BFD full ultra, Idrum, Reason adaptive on two rewires and Albeton Live le on one rewire, Torq rewire on one and eight plug ins. 13%. BFD alone on my dual 1.25 G4 was like 30%. IT has been a massive difference. I don't know which Macbook pro he has but I am betting he'll get the 50% upgrade he is looking for. The 8 plugs (2 british eq, maxim, slightly rude, british comp, Air reverb, BF3a) run at 6%.
Might do some investigation if you're running the i7 with 8.0.3, through an MBox 2 Pro and -- this is the kicker -- connecting the MBox with s/pdif. There's a doozy of a clock source issue there. But it you're not using spdif, then you shouldn't have any trouble.
Tranferring Protools 10 from old iMac to new IMac | JuergenTilak | Pro Tools 10 | 3 | 07-31-2012 08:48 AM |
Protools on iMac i7 | CrAkD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-09-2011 01:17 AM |
will protools 9 run on imac g5 | barra | macOS | 2 | 05-18-2011 12:56 AM |
ProTools LE 6.4, 002 and iMac G5 | shake | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-24-2004 06:15 PM |
Can't get into ProTools 6.1.2 on iMac OS X 10.2.8 | brheaves | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-24-2003 05:17 PM |
