Mac PT8 strike installation
I would think this would be really simple but I can't get it to work correctly. I've installed the DVDs and then applied the 1.0.1cs2 update then the 1.0.2 update. I've tried to run the SetContentLocation and still it can't find the content. It also appears the 2nd DVD puts files 4-6 in the root directory instead of in the Strike directory.
I haven't seen anything that says what to install first but assuming to install the DVDs and not sure which update to install next as I've tried everything. |
Re: Mac PT8 strike installation
I should have noted this is on a macbook pro running 10.5.6 Leopard
A solution has been posted in your other thread to try. There is no need to double post. Besides, this and your other thread are both in the wrong forums. You'd require the Virtual Instrument forum.
filosofem |
Strike installation | markinson | Virtual Instruments | 1 | 12-19-2010 12:18 AM |
Strike installation on mac | srslab | Virtual Instruments | 3 | 10-12-2009 01:19 PM |
Strange Strike Installation | LSW | Virtual Instruments | 0 | 03-15-2008 08:21 AM |
Strike Installation | nozombieno | Virtual Instruments | 1 | 04-02-2007 04:44 PM |
I need Strike Installation Help!!! | claudemorrow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-05-2006 06:31 PM |
