Old 02-12-2016, 10:27 AM
Monty_python Monty_python is offline
Default Video Timecode Issue, confirm I've crewed :)
Hey guys!
Working on an indy feature. Editor gives me a 25fps video and omfs. I edit and mix entire project in PT at 25fps (not realizing the framerate of the vid). Editor realizes afterwards he should have been in 23.976. He conforms his project in FCP7 to 23.976 with no problems on his end. Now he makes a few more edits before locking the film. Now he's sending me 23.976 video back which now doesn't sync with my pro tools session which I edited in 25fps.
Can pro tools conform to this in any way? For example, can it adjust/stretch natively my 25fps session to 23.976? I can do a workaround, but it isn't pretty. Especially if he sells the film and more edits are required at that point. Can Pro Tools get me back on track with out redoing all of my work?
Thanks for your time!
Monty
Old 02-12-2016, 10:35 AM
JuanPC JuanPC is offline
Default Re: Video Timecode Issue, confirm I've crewed :)
Audio can be stretched...
You can load the first video in VLC Player,
VLC Player has a menu to show the Codec information.
You can confirm what is the specifications of the original video file.
But... Usually, ProTools is for Audio...
Video first, then audio...
Same when 35mm was manually.
Editing audio first, gives all kinds of problems.
Old 02-12-2016, 10:47 AM
There's nothing more to confirm, original is 25fps, the project has been moved to 23.976. And yeah, I completely agree. The director thought he was locked, I got the project, and now he's not locked... I have to work with the situation. And I'm sure a buyer may have editing demands as well. So just trying to make sure there's not a pro workaround. Thanks.
Old 02-13-2016, 06:42 AM
Kasper Kasper is offline
Looks like you have 2 issues; the cut has changed and you are at a different speed.
So, you need to adjust your speed first, then conform to the new edit.
Create new session at the proper rate, import session data and SRC from 25 to 23.98, copy audio files. (4.1% rate change)
kasper
Old 02-13-2016, 08:58 AM
Thank you for the reply. So I made sure my my Session was in 25fps by going to Setup>Session. Then started a new project and made sure the new one was in 23.976. Used Import>Session Data from my previous 25fps session. The only place I know to use SRC is in this Import dialog box simply by checking the box. This didn't work, could you critique my workflow if I missed something?
Thanks for your time.
Monty
Old 02-13-2016, 09:38 AM
john1192 john1192 is offline
yes, you did miss something .. the Pull Down to 46,034 (PAL to NTSC, Film Style) .. see pic ..
but listen to the Pitch .. i cannot remember how you fix the Pitch Issue .. taking a look at that now ..
Monty
File Type: jpg Screen Shot 2016-02-13 at 9.29.29 AM.jpg (67.3 KB, 0 views)
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-13-2016, 09:47 AM
it sounds like it is One Semi Tone .. someone Check me on this Please ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-13-2016, 02:08 PM
68 cents is @ 4%
Yes, John has it right, I should have clarified, 46.034 is the right sample rate for the conversion.
You will probably want to correct the pitch after you are done, 4% is discernible. You want to correct the pitch only though, not the time, or you'll be back where you started
kasper
Old 02-13-2016, 02:13 PM
thx Kasper, the VO has some nice body pitched down like that
68 cents is @ 4%
kasper
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-13-2016, 02:16 PM
Yeah, just don't tell them .... they'll think you have some special sauce
kasper
please confirm strange Hi-Pass filter issue... clausiii Pro Tools TDM Systems (Mac) 9 09-11-2009 12:49 AM
Timecode issue, after upgrading to 7.4 PleasantNoise Pro Tools TDM Systems (Mac) 0 06-15-2008 10:16 AM
Could anyone confirm this as a 7.4 issue? RobMacki Pro Tools TDM Systems (Mac) 7 02-07-2008 09:36 PM
Can anyone confirm Waves V-EQ issue? Top Jimmy ICON & C|24 2 05-30-2007 08:50 AM
video timecode tobin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-20-2003 04:05 PM
