Old 05-18-2016, 06:17 AM
starlingmusic starlingmusic is offline
Default Pro Tools HD 12.5 - Naming Track bug
Hi All,
not sure if this were reported or/if it is only with me
Pro tools hd 12.5
Create a new project (empty)
- add 2 audio tracks
- double click on the name of the second track to rename it
- window pop up with option to rename the track
- rename the track with the same name as the first track
- pop up saying there is already a track with this name, click ok
- from here I can't leave the renaming window it get stuck
- I can move the cursor anywhere in pro tools but the click doesn't work
I added some screenshots following the process
Configuration:
Dell Precision Tower 5810
2 screens
Windows 10 pro 64bit
80Go Ram
Pro Tools HD 12.5
HD Native pcie
HD Omni
PC: Dell Precision Tower 5810
CPU: Xeon E5-1620 v3 @ 3.50GHz
GPU: NVIDIA Quadro K2200
Ram: 80GB DDR4-2133 (1066MHz)
OS: Windows 10 Pro
HW: HD OMNI, HD NATIVE PCIe
SW: Pro Tools HD 12.6
http://starling-music.com
Old 05-18-2016, 06:47 AM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
Default Re: Pro Tools HD 12.5 - Naming Track bug
I have seen this too. If you hit the ESC key you can get out of what appears to be a crash. It's just that the buttons stop working. I have only seen this on the Windows side
Sign up for all things....AWESOME!
Kris
May the music move you
Old 05-18-2016, 06:58 AM
Hi Kris,
I just tried and pressed the ESC key,
You are right, it works.
Thanks very helpful.
OS: Windows 10 Pro
Old 05-18-2016, 07:28 AM
Kris75's Avatar
Space Cabin Audio
Drove me nuts too until I figured out I could hit the ESC key! Never realized how often I tried to name a track the same as another until this bug came up! At least the workaround is simple.
Kris
Old 05-18-2016, 11:12 AM
jjnssn jjnssn is offline
Similar behavior in the I/O window where it will appear to lockup and esc is the only way out because a dialogue box gets buried under the app.
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Old 05-18-2016, 03:09 PM
ChazC ChazC is offline
I've had a ticket open about this with Avid, happens when naming groups too. They say they can't reproduce it at their end and insist it's a problem on my system.
Thanks for confirming its not just me!
Chaz
Shifting Sands Audio
www.shiftingsandsaudio.com
soundcloud.com/shiftingsands
Asus X79 Deluxe | i7 4930K @ 4.1 | 32Gb Ripjaws CL9 GBLZ | Radeon R5 230 | Win7 Pro (64) | 256Gb Samsung 850 SSD | 2x 1Tb Seagate SATA | 250Gb Samsung EVO SSD | 128 Samsung SSD | Antec 650W | ProTools 11.3.2HD, 10.3.9HD, 12.5 | Cubase 9.0.20 Pro | Nuendo 8 | Studio One 3.2 Pro | RME UFX | 2x Octopre Mkii Dynamic | Alphatrack | DTouch | Logitech G510 | Kensington Trackball | Yamaha UX256
Old 05-18-2016, 08:06 PM
blackmacdaddy blackmacdaddy is offline
Slightly off topic: (but good to know)
If you do ever want/need to name a track the same name, just add a space after the duplicate name, it will work.
I sometimes use the same name for both my VCA and it's associated Audio Track (ie TAMBO) OR for Doubles and such. Easy quick trick.
It's only R'n'R but I like it.
PT 12.4 Track Commit / re-naming bug kkabel Pro Tools 12 7 02-27-2016 04:45 AM
Track naming from S6? Marsdy Pro Tools | S6 1 01-19-2016 04:06 AM
Track naming crash ZEUSS Pro Tools TDM Systems (Mac) 11 11-28-2006 10:18 PM
Track Naming - Why? PMoshay Pro Tools TDM Systems (Mac) 4 05-26-2006 09:26 AM
Naming a Track Imagine Pro Tools TDM Systems (Mac) 2 11-04-2004 09:55 PM
