  #121
Old 08-01-2019, 05:40 PM
JFreak JFreak is online now
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
Originally Posted by WorldStudios View Post
But they must have thought about this scenario??
As far as I understand this, the drives interface to PCIe and not between each other. Which means copying from A to B goes thru PCIe, and if the PCIe bandwidth is already fully utilized with one drive throughput, you're going to have to install another adapter card for another drive to make it happen.
Only scenario that I can think of where A and B would be linked without talking to PCIe would be RAID configuration, and even then data would not be copied between the drives.
  #122
Old 08-02-2019, 01:00 AM
WorldStudios WorldStudios is offline
I don’t know the maximum capacity of the pci bus, but one is read and the other one is write, so it should be absolutely possible to do this and further more absolutely possible at halved transfer speed in any case.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #123
Old 08-02-2019, 08:07 AM
Ok, guys. The Crest card got here today and I installed it in the 16x slot the closest to the video card in my MacPro. Mojave 10.14.5
Boots just fine.
Before is with the 1gig 970 pro on an older card. After is in bay 1 on the Crest card. As you can see, we are looking at roughly twice the speed.
I popped an older ASHC card into bay 2 in the rest card and it works about the same as before, if anything actually slower.
BUT - I can copy files between both blades without a problem! Perhaps it works because the older card "only" gives around 1000 read and write.
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #124
Old 08-02-2019, 08:18 AM
ghostwriter's Avatar
ghostwriter ghostwriter is offline
I am noticing I need to run one installer at a time to have it be more stable. It varies from the plugin companies too. McDsp and Sonnox were the worst so far. Waves Mercury, tons of Plugin Alliance plug-ins installed without a hiccup. I too believe the full speed may be part of the problem. It’s may be running so fast that it’s tripping over itself. Just speculation though.
I sure wish Samsung Magician came in a MAC version.
A few of of my favorite toys: Retro Instruments 176 (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM 70, SPX90, Roland SDE 3000...
  #125
Old 08-02-2019, 12:49 PM
Using Pro Tools today. Crash, crash, crash.
Not so happy anymore.
  #126
Old 08-02-2019, 01:32 PM
the.engineer the.engineer is offline
That sucks! Is it worth just having one SSD in the Crest to test if it's stable?
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon RX 580 8GB | Apple 27" LED Cinema | 500GB Samsung 960 EVO M.2 SSD System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Mojave 10.14.5 | Pro Tools Ultimate 2019.5 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #127
Old 08-02-2019, 02:19 PM
arche3's Avatar
arche3 arche3 is online now
Wow. Sorry to hear this. Maybe I'll just get single m.2 ssd pcie card. Not the dual switching model like the Crest.
Sent from my SM-G975U using Tapatalk
  #128
Old 08-02-2019, 02:20 PM
I tried erasing both ssd drives in the crest and installing High Sierra on drive 2 and booting from it. I couldn’t get black magic speed test to run, it froze the machine. I’m ready to call it quits. Very frustrated at the moment.
  #129
Old 08-02-2019, 02:21 PM
I’m thinking the same thing.
  #130
Old 08-02-2019, 02:33 PM
Does anyone know of an adapter that holds one 970 evo ssd that will run at 3000 like the Crest did?
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 07:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
