Delay Compensation for Playhead / Cursor
I'm doing some editing on something that I've got some pretty latency-heavy plug-ins on (noise reduction, etc). The cursor is in a totally different place than what I'm actually hearing, so I thought that it would be pretty great if Delay Compensation was also reflected by the playhead / cursor, so that even if you had a boatload of plug-ins, the cursor would actually reflect what you were hearing. seems like it should be possible.
thoughts? |
Re: Delay Compensation for Playhead / Cursor
Even with many plugins inserted, I´ve never experienced that the cursor was in a "totaly different place" compared to what I hear.
Maybe your problem doesn´t have to do with the plugins or ADC. Is it better with no plugs in the channel? What PT version do You have? Martin
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
I do indeed experience this from time to time.
The issue really rears its head if both the track and the subsequent paths to which it’s routed are rich with plug-ins. I really only find it to be a problem when I’m cleaning up tracks from clicks, pops, and crackles — where the disturbance is often hard to see until zoomed in at near-max resolution, at which point scrubbing becomes nearly useless. In answer to Muzoid’s question, my “solution” is to temporarily disable the longest latency-laden plugs and reroute the track in question to my monitoring path, which is plug-in-free*. Sure, it’s not “instant,” but it’s an eminently workable way out. * Although I keep an otherwise disabled low-latency limiter on this strip for the purpose of “enhancing” scrubbed sound and protecting monitors and ears. IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Finally! I've posted a similar thread two months ago:
http://duc.digidesign.com/showflat.p...v=#Post1146580 |
Thanks Tal (for your reply)
I wasn't having a problem working with it and of course, could have either disabled the plugs while editing or rerouted, but was trying to tweak as I was editing in an effort to save time. I just thought that the idea to have the playhead / GUI reflect what was actually being heard was a pretty good one and wanted to pass it on. Best regards, Bill |
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing | CNSound | macOS | 1 | 01-27-2012 11:10 AM |
Stationary Playhead Cursor | benjamingolby | Tips & Tricks | 2 | 07-30-2011 07:41 AM |
Delay compensation- choice of 'Medium delay'? | dtmprod | Pro Tools TDM Systems (Mac) | 2 | 05-05-2010 11:00 PM |
Delay Between Audio Playback and Playhead Position | Dan Zimmerman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-10-2010 10:09 PM |
Update edit cursor...stationary playhead. | Porky | Pro Tools TDM Systems (Win) | 0 | 02-26-2010 11:44 AM |
