Old 06-12-2017, 04:14 PM
SBP SBP is offline
Default Clip Effects
I've been using the clip effects on a bunch of small projects and its a great feature however;
1-be cool if bypass was the default -ie All clip effects default to an 'inactive' state.
2-I find the processing state visual impossible to read when I have lots of tracks or am zoomed out [Or when I am at the start of a clip that extends longer than the edit window] -a band or something around the clip would be clearer. It would be great to have the processing state display in edit window much clearer.
3-It would be great if clip effects were included when you export a 'clip group'
4-I find myself selecting a clip in the edit window then going to the clips bin and selecting "object select in edit window" often. -this is so that all of the 'other same' clips used in the timeline get the new settings -however the time line then plays from the first clip (unless I unlink the track and edit timeline selection) I find this clunky -it would be good to streamline the option to "edit clip effects for all same clips used in timeline" or "edit selected clip only" -I can see a bunch of easy ways to do this -perhaps a selector where the clip name is.
Just my thoughts thanks for the useful addition.
All the best
Bruno
Old 06-12-2017, 04:19 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Clip Effects
Hi friend interesting
> http://protools.ideascale.com
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Disable Clip Effects markuse_23 Pro Tools 12 0 01-31-2017 03:06 AM
Cannot Edit Clip Effects in PT 12.6 HD conleec Pro Tools 12 81 01-30-2017 07:55 PM
What's so special about clip effects? Darryl Duncan Pro Tools 12 22 10-25-2016 09:11 AM
Clip Effects Freezing Carl Lie Pro Tools 12 3 10-05-2016 04:24 AM
Clip Effects - Compression Metering?? off the wall Pro Tools 12 8 09-30-2016 09:59 AM
