Old 04-13-2007, 09:01 PM
Dragle Dragle is offline
Default Drag and Drop not working
I have not been able to drag and drop audio regions into structure. I'm using Pro tools LE v.7.3.1 on a Mac Pro.
Old 04-16-2007, 06:10 AM
sunsinger sunsinger is offline
Default Re: Drag and Drop not working
I am experiencing this also... some folks say that the regions must be converted to audio files...
but this also does not work... no sucess with this function at all...
They're unlocking the picture on me again!!!
Old 05-02-2007, 11:19 PM
Hbreaker Hbreaker is offline
Me either, I had to bounce out the audio and then import it using the replace sample option.
Am I doing something wrong?
Mac G5 DC2Ghz 2GB 160/250GB, PT7.1cs10, HD2
Old 05-31-2007, 04:04 PM
Chri Chri is offline
Same here. I assume this feature just didn't make it yet to the current public beta.
In the Pro Tools Accelerated Video they have it though.
Too bad, I really wanted to try this right now.
Old 05-31-2007, 08:08 PM
bassntreble bassntreble is offline
Working fine here. Can drag and drop from region list, workspace or directly from edit window.Single or multiple samples.
Only with .rex files is it sort of weird. Each slice in a rex file should be consolidated before drag n' drop, otherwise it imports wrong. This should be fixed.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired)
MBP C2D 2.4/4GigRAM/Mbox/8.0.1
iMac i7 3.4/16GigRAM/10.0.1
Old 06-19-2007, 08:18 PM
Wayne Rose Wayne Rose is offline
I did find that attempting to drag and drop regions from the edit window would not work with Edit Mode in Shuffle -- had to switch to Slip Mode, then it worked fine.
I tried this several times in several different sessions with the same results.
Looks like a fix is required. Great package though!
Drag and Drop files on Mac not working cuttothebeat Pro Tools 11 5 01-31-2014 02:23 AM
Windows 8 Drag and Drop not working notedmusic Windows 1 01-23-2014 09:18 PM
WorkSpace Drag and Drop Not Working in PT11? quantise Pro Tools 11 0 08-14-2013 07:29 AM
PT 8.3cs2 drag & drop not working syti13 Pro Tools M-Powered (Win) 2 05-02-2010 09:59 AM
Drag and Drop Not Working ryanoelke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-10-2008 11:06 AM
