Can't drag and drop any audio from Explorer
Hi there,
Specs below... I can't drag and drop any audio files (have tried with different file types and sample rates, both matching project conditions and not) from an explorer window into pro tools. I can do this on any other DAW I have, and it makes importing multiple files very frustrating and time consuming. Also when using the import audio file, it doesn't remember the most recent place, so each time when I import a file, I have to search through my drives to reach the right place which adds so much time especially when I am using a lot of tiny SFX files for sound design projects. Is there a way to set it up so I can just drag any number of audio files into the mix window and it automatically import/convert the files? I've just got Pro Tools Version 2018.10. Have a very new high spec PC running Windows 10 with specs below. When I try and import it just gives me the black circle with a cross through. Any ideas would be very appreciated for how I can fix this, and speed up audio import because for the minute I keep going back to Reaper to save time and anger! Thanks everyone, Will System DetailsEdit Value Intel® CoreTM i9 18 Core Processor i9-7980XE (2.6GHz) 24.75MB Cache, Motherboard Gigabyte X299 AORUS Gaming 3 PRO, Memory (RAM) 32GB Corsair VENGEANCE DDR4 3600MHz, Graphics Card 8GB NVIDIA GEFORCE GTX 1070 Ti 1st Hard Disk 2TB WD BlueTM 3D NAND 2.5" SSD 2nd Hard Disk 8TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE Focusrite Scarlett 2i2 Pro Tools 2018.10 64bit Last edited by WillSullivan13; 12-01-2018 at 07:55 AM. Reason: Specs didn't show up |
Re: Can't drag and drop any audio from Explorer
Something is wrong if it won't even let you drag wav files from explorer into the track list/edit window timeline or clips list. Sample rate conversion is automatic but you need to install Quicktime to import mp3 etc.
Are you a new PT user or is this just a recent problem that has come up? |
Hi. If you followed the Pro Tools Windows 10 optimizations then you're running PT as an administrator which prevents drag-n-drop from other apps like windows explorer.
You can right click on your PT.exe, go to properties/compatibility and deselect run as administrator. You'll now be able to drag-n-drop. I've never noticed any adverse affects from doing this and my workflow has no flow at all without it. If I ever have to troubleshoot anything with PT the first thing I do is re-enable run as admin but it's never been the culprit so far. I actually wish that Avid would shed some light on this as it seems that running as admin is unnecessary and very limiting. I see no difference on my system with it on or off. Other than disabling a feature that I really need. Regards, Marc |
Thanks for the reply,
I'm a completely new user, just bought PT in the last couple of months as I'm about to begin a MfA in Composition and Sound Design and they recommend using it for a lot of the modules. I have Quicktime installed, and all the most recent updates on PT. |
As mentioned make sure your are NOT running Pro Tools with Run As Admin.
Second, you don't drag into the MIX window. You drag into the EDIT window. You could drag into the Tracks List in either window.
Thanks everyone, you hit the nail on the head.
I turned off run as admin and can now drag and drop with no issues. Best, Will |
After reading this thread, I pulled Pro Tools, Reaper, Ableton Live and Studio One out of "Run as Administrator" mode, and I can now drag files into each program from Explorer. It's a MS thing. tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X |
This is why I like forums - I had no idea about the Administrator thing, truly bizarre - thanks for posting the solution Marc.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
drag and drop audio??? | rdpar | Pro Tools 2018 | 2 | 07-25-2018 09:55 AM |
Drag and drop from explorer not working (PT12.7 HD) | mdb | Windows | 0 | 05-11-2017 12:24 PM |
Windows 10 | Drag&Drop from Soundbase to Explorer & other Software | astey | Pro Tools 12 | 4 | 03-03-2017 08:34 AM |
Audio import Drag and Drop bug? | colinmansfield | macOS | 4 | 02-08-2012 06:08 AM |
Windows Explorer drag and drop audio files to PT8.0.3 | Buccanears | Pro Tools TDM Systems (Win) | 9 | 03-20-2010 09:05 PM |
