Old 01-13-2021, 11:34 PM
JustinTerrell JustinTerrell is offline
Default Audio Interface with input for Dock and S1
Hey! I'm wondering if there is an audio interface that has an ethernet port that will connect a Dock and S1 to Pro Tools (or any other DAWs). I found the MOTU 828es. It has an ethernet input that is AVB/TSN. Will the dock and S1 connect to Pro Tools through this interface?
Old 01-14-2021, 07:18 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: Audio Interface with input for Dock and S1
The Dock and S1 should go into a Router and then the Workstation. If you want to add an Audio over Ethernet I/O interface I would plug this into a second Ethernet port on the Workstation.
Old 01-14-2021, 12:15 PM
Thanks for the response! That way of connection was already understood. Are you implying that it is not possible to find an audio interface that can connect the Dock and S1 to Pro Tools? That is what I'm looking for and that is what my question is about.
Old 01-14-2021, 05:20 PM
EddieJones's Avatar
I think I'm confused as to what you are trying to achieve? The Dock and S1 don't have any audio in them. An I/O doesn't have an ethernet switch in them.
Old 01-19-2021, 05:13 PM
What I am trying to achieve is a connection between a Dock/S1 and Pro Tools through an audio interface. If it is not possible then it's just not possible. Midi devices can not have audio in them yet they can still be used through an audio interface. The audio interface that I mentioned initially when I first mentioned what I'm trying to achieve has an ethernet port. I was going to get that and try but some have told me that it doesn't work. I'm considering renting one to see if it works. If it doesn't work I am looking for an audio interface that will work for what I'm trying to do.
Old 01-20-2021, 06:58 AM
its2loud its2loud is online now
The Moti 828es is an audio interface than can be attached to an existing Network or to another Motu device via Ethernet for expansion, control, and audio distribution across a network.. It is not a network router or switch. Once you build an existing network infrastructure you can attach all three devices to that same network but you cannot attach a Dock or S1 via Ethernet to the Motu and expect either Avid device to work as they should.
Old 01-23-2021, 11:22 AM
Got it! Understood. Thank you!
S3 as EUCON (with Dock) and AVB Interface ViciousLullabyz Avid S1, S3, Dock and Control App 4 06-21-2020 04:25 PM
Audio input "interface" is greyed out Thirteenth Soul Getting Started 2 12-17-2018 07:13 AM
Input monitoring button in Dock Maro Records Avid S1, S3, Dock and Control App 9 04-08-2018 12:11 PM
Input Tracks 5-8 from M-Audio Interface Won't Show agilblom Pro Tools M-Powered (Win) 1 11-27-2009 04:56 PM
How can I use 001 interface for audio input outside of PT? VanEdge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-27-2001 12:06 AM
