Old 11-20-2013, 01:45 PM
Connor Connor is offline
Default PT 11 Sustain Problem while recording
I have an Axiom Pro 61 with some MGear Sustain pedal.
Running PT11.01 on Mac OSX 10.8.5
So when I play piano just monitoring it the sustain pedal works and feels natural.
When I record the performance. There is a noticeable delay on the sustain pedal which messes up my performance resulting in a chord not being sustained properly.
It is consistent in multiple piano plugins from Kontakt to Mini Grand.
My playing is consistent. and this problem is persistent.
I have tried different buffer settings. I have tried Low latency monitoring On and Off.
It only happens when I record though. When I am just playing around with the track armed everything is fine.
Why is this?
I never had this problem in PT10.
And yes I am aware of the Hyper Control track select record arm Glitch. I took off HyperControl to see if my sustain pedal problem would go away. No such luck.
Thanks, Connor
Old 11-20-2013, 02:22 PM
Marenta Marenta is offline
Default Re: PT 11 Sustain Problem while recording
I have the exact same problem
M
Old 11-20-2013, 02:53 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Have you tried to install the PT midi drivers or reinstall them? It seems strange to me this only happens during recording.
http://avid.force.com/pkb/articles/e...nload/en379411
Under Additional downloads there is the Midi driver installer
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Old 11-21-2013, 07:50 AM
mookai1973 mookai1973 is offline
so many problem on PT11.
Kai
Sound Department
www.phuket-fantasea.com
Phuket Thailand
1.Pro Tools 11.0.2 003Rack Mac Pro OS X 10.8.4 8Gb Ram
2.Pro Tools 11.0.2 003Rack Mac Pro OS X 10.8.4 8Gb Ram
Old 11-26-2013, 12:43 AM
I will try that midi driver soon. Will post results asap
Old 12-19-2013, 05:28 AM
stigc56 stigc56 is offline
Sustain pedals that not record properly and a click that goes bananas.
What is going on here?
Old 12-24-2013, 11:24 PM
drumdandrum drumdandrum is offline
I am also experiencing this... Also when you play back the performance, all of the sustains are there. But while monitoring the performance during recording, it doesn't seem to detect the sustain properly, resulting in dropped sustained notes... Very frustrating when trying to record. You have to "assume" that you played it correctly.
Old 12-25-2013, 02:53 AM
tonwurm's Avatar
tonwurm tonwurm is online now
I can remember that I had a similar problem with PT8
workaround was to deactivate midi merge (at least during recording)
Mac Pro 2010: PT12 Ultimate 2020 on High Sierra, PT10 HD3 on Mavericks, Logic X, Digital Performer, VEPro
MacBook Pro: Logic X, Mainstage
Old 12-25-2013, 07:46 AM
JFreak's Avatar
JFreak JFreak is offline
That has never been fixed completely, so it's still there.
Janne
Old 12-25-2013, 12:03 PM
Big. Relief!.... Works perfectly now.... Thanks guys!!!
Sustain NOT recording in pro tools 9!!! geoffvernon Pro Tools 9 7 03-29-2014 05:38 PM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 01:56 AM
Double notes when recording w. sustain? Sandager 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-07-2007 02:09 AM
sustain cuts out while recording midi tromostheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-08-2007 06:29 PM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-10-2003 12:25 AM
