Connecting Sub to 003 rack
Greetings!
I am new to the 003 world and have just set everything up. I am using Yamaha HS 50M monitors with the HS 10W sub. I can't seem to figure out exactly how to hook up the monitors and the sub so that both are functional at the same time. I have the monitors hooked up to the main monitoring inputs on the back of the 003. Where does the sub go? I had it in the Alt ins, but then it would only activate when the Alt button was selected on front, thus nullifying the monitors... This may seem dumb but I am stuck. Any help would be great! Thanks a lot. |
Re: Connecting Sub to 003 rack
I don't have any of those speakers, but a quick look at the sales literature seems to indicate that you connect the subwoofer to the 003 monitor outputs, then connect the full-range speakers to the outputs on the sub.
www.barnabas.com Barnabas MultiMedia |
You may want to get your hands on a passive studio quality crossover, I would hesitate to be filtering my monitors signal path through the electronics of a subwoofer. You need precision in monitoring and any degredation will only hinder your ability to mix well.
I have the Central station, and after a member of the DUC advised, I plugged the output of my Mac's optical into the Central Station as well, now it has everything from both the computer and my PT rig. http://www.sweetwater.com/c417--PreS...tor_Management Good luck... |
Connecting Eleven Rack to Digi 002 Rack | TMitchJobe | Eleven Rack | 12 | 02-02-2013 10:54 AM |
Help Connecting 003 Rack and C|24 | GCSC | ICON & C|24 | 5 | 07-12-2011 11:00 AM |
003 rack not connecting | decayd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-07-2008 08:42 AM |
002 Rack Not Connecting to G5 | majikdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-20-2008 01:52 PM |
rack not connecting | andymae | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-18-2007 05:14 PM |
