Old 03-12-2008, 06:09 PM
ericbpawsinc ericbpawsinc is offline
Default Newby MIDI playback problem - no audio during playback
My hardware setup is PT LE, Mbox mini, Yamaha PSR 230 MIDI keyboard connected to Windows XP system via Roland/Edirol UM-1 USB MIDI interface. I created a MIDI track, set the input to the keyboard, and can record the MIDI input without problem. I can see the MIDI data in the track, and during playback I can see the record levels jump. My problem is that I can not hear any of the MIDI audio during playback.
Based on the beginners DVD I watched, I believe I need to add an AUX or instrument track, add Reason to this track (not sure how), and then direct the MIDI track output to the Reason track.
I tried the above, and tried every combination I could think of for the input and output of both the MIDI and AUX tracks, but no sound... I assume my monitor is setup properly, because if I add an audio track and record from my guitar (through the Mbox mini input 1), it plays back fine.
Any assistance would be greatly appreciated.
Thanks
Eric
Old 03-12-2008, 06:41 PM
spkguitar's Avatar
Default Re: Newby MIDI playback problem - no audio during playback
This is a common mistake that new users make. There is no such thing as "MIDI audio".
MIDI can really be described as "electronic sheet music". The MIDI data that you have recorded is the sheet music. The Computer is the musician that is reading the sheet music. What instrument is that musician playing? Unless you define that, no music will be produced by the "musician".
Instruments for MIDI can be either hardware or software. You can use either one for the instrument that you want the computer to play, but you still need to select and configure the instrument so that the "musician" knows which instrument to play.
When you play your PSR, you are probably hearing sounds, correct? If those sounds are the sounds that you want Pro Tools to play (that is the "instrument" you want he "computer musician" to play), then you need to hook up the unit correctly to do so;
  • (MIDI cables in both directions, from PSR MIDI output to UM-1 MIDI in, and from UM-1 MIDI output to PSR MIDI in, and then audio cables from the audio outs of the PSR to the mBox inputs
  • those inputs selected an aux or instrument track
  • set the MIDI output of the track to be the port that is connected to the PSR MIDI input
If you want to use Reason as the "instrument", then you need to set it up correctly as well. I have a few tutorials on how to use Reason on my website, as well as a few other tutorials that you might find useful and informative as a self-proclaimed "newbie".
Old 03-12-2008, 09:05 PM
spkguitar,
Your reply was extremely helpful. Makes perfect sense, and my problem is now solved.
Thanks!
Playback Problem: Overpowering Static Noise: Pro Tools can not get playback fast enou JLue Pro Tools 9 1 08-04-2011 08:59 AM
CORRECTION: Adat Device doesnt playback audio during Recording or Playback DarylBham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-21-2010 11:16 PM
help!! midi playback problem. t.ross64 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-13-2010 06:30 AM
Problem with Midi Playback [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-07-2009 02:47 PM
midi playback problem MunchieLad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-21-2006 02:30 AM
