Old 11-05-2007, 02:50 AM
Sandager Sandager is offline
Default Double notes when recording w. sustain?
Hello all -
I don't know if this has been up before, but I couldn't find anything, so here goes:
When I record piano with sustain pedal via MIDI, ProTools "doubles" my notes?
It records the actual thing I play + the same in very short notes.
This makes the playback "die" or after only a split second and not the full duration of the chord.
I have experienced this on both the big HD system but also on my small Mbox2 mini.
Am I doing anything wrong? I want to record both the sustain action and the notes I play.
(it takes time to draw the automation afterwards)
I have ProTools LE and Korg/Nord MIDI devices.
Thanks in advance.
Morten Sandager
Old 11-05-2007, 10:27 AM
DiAngelo DiAngelo is offline
Default Re: Double notes when recording w. sustain?
Same thing happens to me. I don't even use sustain most of the time (it's bad practice to record non-piano midis with a sustain pedal) and I still get the duplicated midi notes...
Pro Audio + Mixing:
http://www.moozek.com
Old 11-05-2007, 10:34 AM
spkguitar's Avatar
Are you sure it's not the controller? I never have this issue with the sustain pedal on my controller.
Old 11-05-2007, 11:16 AM
DigiTechSupt's Avatar
Is this possibly happening during a punch-in?
Avid Audio Tech Support
Support FAQ
Old 11-07-2007, 02:09 AM
Dylex Dylex is offline
I was having the same problem until I realized my
controller had multiple zones or groups active.
- When I reset my controller to a single zone, it
corrected the problem.
hope this helps someone...
Dropped notes, sustain problems, random notes Gamling MIDI 4 02-10-2014 08:09 PM
MIDI notes don't sustain after being pasted jimthepisces MIDI 1 01-08-2008 07:28 PM
double notes john1192 MIDI 0 04-17-2007 09:03 AM
Double Notes!!!! roziel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-02-2007 10:30 PM
Move Notes and Sustain at once? NuBus MIDI 1 01-14-2003 12:06 PM
