Old 09-26-2019, 05:11 AM
RecRoom RecRoom is offline
Default Selecting tracks in Eucon?
Is there a way to select a specific track in Eucon? I've tried "Scroll to track" enter the first letter of the track, and hit return, but it doesn't seem to work. Any other obvious way that I'm missing?
Thanks!
Jeff Hinton
Editor/Mixer
http://www.jeffhinton.tv
Old 09-27-2019, 07:51 AM
EddieJones's Avatar
Default Re: Selecting tracks in Eucon?
There are many ways to select a track in EUCON...but first is that what you mean. Are you trying to get a track you click on in PT to attention to the surface ?
Old 10-07-2019, 08:45 AM
Hi Eddie,
I want to program a macro to mute/umute a specific channel.
Here are the steps that I've entered:
1) Eucon -> Scroll to Track
2) Key -> first letter of track
3) Key -> \n (or Return)
It gets stuck here. I think the macro fires so fast the the letter isn't being read. I've tried both the Eucon Scroll to Track and the key combo Option + Command + F. Putting in the pause key command (\a) seems to have no effect.
Also, I would love it if you guys programed a macro to open the rename dialog of a track. I record ADR for a living and that would be amazing.
Jeff Hinton
Editor/Mixer
Old 10-08-2019, 07:20 PM
EddieJones's Avatar
Adding a proper pause is on our list of things to do and would probably help here
Old 05-02-2020, 11:15 AM
IntelDoc IntelDoc is offline
Did anything ever come of this effort?
I have a workflow on the Avid Control app that I would love to be able to implement selecting a track.
example:
I make memory locations that will use both a view and a windows configuration.
1. I make a window Configuration that will minimize all other track folders BUT the drums, and set the track height to medium.
2. I set a memory location called DRUM EDITs that will call this window config as well
3. I then hit VCA *drums* on the app to select the Drum VCA and spill that to the faders.
Would LOVE to be able to add this to the memory location to allow one button. It would call the VCA as well as the window config at the same time.
Should be super simple to either allow this as a feature when you create a memory location - OR, just allow a eucon macro to say slect "this track, etc"
MONUMENT SOUND
MONUMENT SOUND ON YOUTUBE
Monument Sound Facebook
"Changing how people hear music one track at a time"
Any Eucon (soft key) command for directly selecting sends ? Uli Auer Artist Series 0 05-12-2019 05:17 AM
11.3.2 selecting across random tracks bug? Frank Kruse Pro Tools 11 2 09-23-2015 01:25 AM
selecting tracks or sections of tracks drummerfreak33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-24-2004 01:33 PM
Selecting discontiguous tracks in PT6 Farmer Dave Pro Tools TDM Systems (Mac) 0 02-03-2004 12:37 PM
Selecting all tracks Mocha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-26-2001 12:44 AM
