Hide folders but not tracks
I already know the answer to this, but I'm asking anyway in the hope someone has an idea that could work for me.
I love to use folders, especially for mixing, but when I'm writing I like to have instrument tracks stacked directly on top of each so I can see what's going on. It would be great I there was a way to hide the folders but not the tracks in the folder. I find myself moving tracks out of the folders when working then having to move them back at the end which is time consuming. |
Re: Hide folders but not tracks
That is a shortcoming of things as they are now. A better bet would likely be to leave folder tracks out of your template and add them later, or use the tried and true Bus>Aux method that doesn't "glue" itself to the tracks that route thru it.(those Aux tracks can be converted to Routing Folders later)
Edgar Rothermich Author of "Pro Tools 2020 - How it Works" from the Graphically Enhanced Manuals (GEM) series http://DingDingMusic.com/ YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/ |
Another thought I had was a "move to parent" option. This would work well because currently if you move a track out of a aux folder the routing doesn't change. This way you could move tracks around and at the end move them back to where they belong easily. |
You are right, moving that ins and out of the folder would be quite messy, especially with Routing Folder Tracks. Maybe it is also messy when coding a "Show/hide Folder (but not its Member Tracks)" and that's why it is not available. Although it would be a cool feature.
This seems like a thoroughly daft idea to me but maybe I haven't got my head around the concept.
You could create a midi track for each instrument, and program from there.
In the Edit window, you can at least make folder tracks "micro," which makes them nearly hidden. But in the Mix window, unfortunately, they take up whichever track width the rest do. As someone pointed out, hidden folders could be dangerous. It could result in inadvertently moving a track out of its routing folder, which would change the mix. Maybe an acceptable compromise would be to allow folder tracks to be extremely narrow in the Mix window as well as the Edit window. The names would be unreadable, but colors could still be used for reliable identification.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
I solved this by having each VI-based folder (Strings) having a Basic sub-folder called “Inactive (Strings)”. All VIs are in there, deactivated, and the ones I use, I pull out to the main level of the (Strings) Folder (and activate them). This way, I can Hide the Inactive sub folder and only see the Instruments and the top-level Folders (which I shrink to Micro while working)
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
Show/Hide Tracks | clausiii | Avid S1, S3, Dock and Control App | 2 | 10-25-2020 01:00 AM |
Hide / Show Tracks | SL1 | Post - Surround - Video | 3 | 07-14-2016 02:58 PM |
how do you hide tracks? | yanncrusoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-28-2008 03:56 AM |
Hide and Show tracks bug | Ray Lyon | Pro Tools TDM Systems (Mac) | 6 | 05-13-2005 07:08 AM |
Show hide Tracks | ZEUSS | Pro Tools TDM Systems (Mac) | 3 | 07-03-2004 09:11 AM |
