Inactive Inputs help please!
Hey Everybody
I'm guessing there is an easy answer to this that I am missing out, however, as I am fairly new to PT I figured I would ask the pros since I'm not making any progress with this. I have PT10 installed on my MacBook Pro. I record in my rehearsal space using a Presonus 10 channel interface. When I leave the rehearsal space and go home I usually don't have an interface so when I open the PT session I'm usually running direct out of my laptop's audio out. So I know PT automatically adjusts my i/o settings to make this happen. When I return to the rehearsal space and connect my interface all of my inputs are greyed out and I have to go in and reassign them all again even though they already show the correct assignment in the greyed out portion. Is there a way to reassign them automatically or all at once. It kind of sucks having to reassign each input every time. Thanks for your help! |
Hold the option key while changing one output and it will do it to all of them...
Hope that helps :) Db Arcadianrecords.com Soundmatrixstudios.com |
Re: Inactive Inputs help please!
Ahh yeah I do know about the option key. However, I was hoping to find a way so that the inputs go in ascending order (i.e. kick mic input 1, snare mic input 2 etc.). When I use the option key it seems to turn all of the tracks to the same input.
Ohhhh my bad I thought you meant outputs.... In that case hold option + command. That SHOULD put them in accending order :)
What you need to do is save two of the same sessions .
the first with all your i/o the way you want it . and another so that when you open it the i/o doesn't get lost . then just import everything into the first session with your i/o. Or you could just duplicate your tracks and make them inactive for standalone use and use your duplicates instead. Drag any revised tracks onto the actual track . No remapping at all . Just make sure to set them as inactive Thats how I would do it but there is probably is a better way. |
Can't Remove Inactive Inputs | jblass | macOS | 3 | 12-30-2011 02:36 PM |
Pro Tools 10 - Inputs inactive | migu | Windows | 8 | 10-29-2011 08:21 AM |
all I/O became inactive | peteor96 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-12-2011 08:17 PM |
Analog inputs 5-8 not seen as inputs on tracks | sitarartist | Pro Tools M-Powered (Mac) | 4 | 09-16-2010 08:24 AM |
How do I utilize the Line inputs when all my XLR inputs are being used? | 007audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2009 08:21 PM |
