Old 11-14-2010, 07:58 AM
db5 db5 is offline
Default Pro Tools Error message Assertion in"/Volumes?/Development/ws.Preston/AlturaPorts etc
Has anyone encountered this type of error message after installing PT9 on a MacBook 2.4ghz Mac OS 10.6.4
Assertion in"/Volumes?/Development/ws.Preston/AlturaPorts/NewFileLibs/CoreFoundation/MacBuild/../../Sys/MacOS/Sys_FileLocmacOS.ccp", line 231
Old 11-14-2010, 08:19 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Pro Tools Error message Assertion in"/Volumes?/Development/ws.Preston/AlturaPorts
Usually indicates a hard drive/data base issue. you could try running this app to remove all prefs and database files...
http://duc.digidesign.com/showthread.php?t=190122
If this is an update i would use the uninstaller in the digidesign folder in applications. and uninstall PT using the clean uninstall. This will not remove or effect any third party plugs etc, it will just replace the PT files and included plugins.
then repair disk permission and reboot before install PT9 complete install.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-16-2010, 04:28 AM
db5 db5 is offline
Thanks for your suggestion. Sadly doesn't seem to want to play, although I can launch PT and then open the file from there. Song file must be getting corrupted somehow.
Old 11-16-2010, 06:06 AM
crizdee's Avatar
Have you tried opening a new session and using import session data to import the tracks? maybe try a few at a time and see if it indicates which tracks causes the issue. most likely one track with a specific plugin on.
Also could try removing all plugins from the plugs folder! (libray/app support/digidesign/plugins) except the stereomixer.dpm and see if the session opens up with no plugins.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-16-2010, 05:20 PM
db5 db5 is offline
Problem solved! Don't understand how it happened but a spare PT9 launch icon managed to install itself in my hard drive folder, so there were two, one inside the digi folder and another which was obviously causing a conflict. Thanks for your help db
[IMG] code is Off
Assertion in "/Volumes/Development/vbpc/AlturaPorts/SDKs/Neo gb studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-30-2014 08:56 AM
Assertion in " / Volumes / Development w.s Pro Tools 8.0X/ Alturaports PT4_App error Reactive Doze Pro Tools M-Powered (Mac) 1 09-12-2012 08:41 PM
can't open file! assertion in "/volumes/development... tsitrainbow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-12-2011 10:21 AM
Weird error code Assertion in "/Volumes/Development glandau Pro Tools TDM Systems (Mac) 2 03-08-2011 12:52 PM
error code/ neo assertion"/volumes/development univox1 Pro Tools TDM Systems (Mac) 3 09-16-2009 07:30 PM
