Old 03-07-2021, 06:18 AM
[email protected] accardi@accardi.com is offline
Default Pro Tools First and clip gain functionality
I'm getting the impression that Pro Tools First does NOT support clip gain. So is there a workaround to accomplish the same thing in First? adjusting pre processing gain on my tracks so they are all similar to each other before I post process? Thanks in advance for any advice here.
Old 03-07-2021, 02:04 PM
Default Re: Pro Tools First and clip gain functionality
Using the Audiosuite GAIN plugin is how I did this before we got CLIP GAIN. Having said that, I would also suggest you buy the "real" version of Pro Tools. While you probably don't need "Ultimate", PT First is nothing but a tease and you will outgrow it really fast due to the countless shortcomings it has. If you can't afford to have the "right tool" for the job, ask yourself if you need Pro Tools, or if another DAW would make a better choice? Reaper is free to try and cheap to buy(and can do pretty much everything you will ever need). Cakewalk by Bandcamp(formerly SONAR) is completely free(and both run VST plugins). If you run a Mac, Logic is another solid option.
Pro Tools 12 Clip Gain Issues? maxgain Pro Tools 12 11 08-28-2020 11:14 AM
Do not upgrade to Pro Tools 12.7 - Clip Gain Bug madmith Pro Tools 12 1 02-13-2017 09:08 PM
Pro tools 11 Clip Gain Issue Cheskie Pro Tools 11 9 10-02-2013 10:12 AM
Clip gain issue when importing AAF in Pro Tools 10 chefbrody macOS 4 03-28-2013 07:53 AM
Pro Tools 10 Sync and Fade Problems using Clip Gain mediaroo Pro Tools 10 5 08-17-2012 08:18 AM
