Old 04-10-2020, 01:59 PM
dg27's Avatar
dg27 dg27 is offline
Default new install of Pro Tools 2020.3: two questions
I just finished installing PT 2020.3 and all of my plugins. in 6 cases plugins created their own folders within "My Documents," but not inside the Pro Tools folder. I'm assuming that I can't just move them in there, right? (These folders have the presets.)
I've been using Trasher 3 for a while now, but I'm unsure whether I should back up everything that's listed. I know that in most cases you don't restore everything, but I can't remember whether in the past I backed up everything (or whether that's advisable).
Any advice would be appreciated.
Thanks.
Old 04-10-2020, 07:14 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: new install of Pro Tools 2020.3: two questions
Thanks.
I've never seen this before. All AAX plugins should go into the PT plugins folder. You don't even need to do anything; it's automatic. Maybe you should uninstall and re-install those plugins? Was 2020 a clean install? In my experience with Windows things can sometimes go wrong if you install on top of an older version. I don't think Mac users have that problem. If it wasn't a clean install, you may be able to save yourself a lot of trouble by redoing it. You can backup stuff in Trasher if you are happy with what you are backing up. If not, you can always redo it.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 04-10-2020, 09:10 PM
dg27's Avatar
Thanks, for your reply, lesbrunn.
This was a clean install of 2020.3 soon after a clean install of Windows 10 Pro.
I think I'll just uninstall and reinstall those six plugins.
I don't use the Windows "My Documents" folder for anything other than programs that put files there (like Pro Tools). But I don't like having random folders for loose plugins outside the PT folder.
As for Trasher, I just back up everything.
Thanks for your help.
dg
Old 04-11-2020, 06:39 AM
EGS's Avatar
EGS EGS is offline
I'd let the plug installer put things to whatever default location it wants. I do, however, install (or move) all VI sample libraries (but not the plug) to a separate drive.
Click for audio/video demo
Click for resume
Old 04-11-2020, 07:34 AM
dg27's Avatar
Thanks for the advice. Just to rule out any errors, I think I'll try uninstalling and reinstalling a couple of these to see where they put them. I have all my presets backed up on other drives.
Be Quiet Pure Base 600 case * Core i5-12600K * Gigabyte Z690 UD AX * 32 GB G.Skill Ripjaws DDR4 * 2X HP DreamColor Z24x G2 displays * NVIDIA GeForce GTX 960 * Samsung 980 boot drive * Samsung 870 EVO PT projects drive * Samsung 860 EVO PT archive drive * Novation Impulse 49 MIDI * PreSonus Studio 26c interface * PreSonus Bluetube V2 preamp * PreSonus HP4 headphone amp * JBL LR 305 monitors * Sennheiser HD 650 headphones *
Windows 10 Pro 64 21H2, Pro Tools 2022.7.0
Old 04-11-2020, 02:49 PM
EGS's Avatar
EGS EGS is offline
If you decide to re-install a plug:
1. uninstall
2. CCleaner (I use the free version) & run this https://www.ccleaner.com/docs/cclean...istry-cleaning and then this https://www.ccleaner.com/docs/cclean...eaning-your-pc
3. Check the plug website and DL the latest version, re-install
4. reboot & launch Pro Tools
Click for resume
Co-install PT 12 and PT 2020.3? sw rec Windows 7 06-15-2020 10:09 AM
Cannot install Pro Tools 2020.3 (macOS) iz_thewiz Pro Tools 2020 1 04-06-2020 12:16 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
Cannot install Pro Tools 2020.3.0 on Catalina in any which way moyno85 Pro Tools 2020 3 04-04-2020 03:41 AM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
