#21
Re: do you have probs w/ digi tech suprt utility?? i got a fix!
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#22
Thanks. I appreciate your reply. Can I also assume it will trash everything on all drives?
I have audio D drive, C drive (System), and data e drive all sata and internal. Does it also delete volume folders and everything the other utility was supposed to? I am installin 8.0.1 now...wish me luck!
"It aint about the stuff you got..If it sounds right you're finished..Burn it!" For all complaints click here DAW-Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent |
#23
yes it will trash the databases on all drives that are hooked to the system as well as the prefs and app data folder on the c drive. there is an enclosed read me with it that has details and different options.
most of the 8.0.1 upgrades are going fine. i did mine in about 10-15 min and did not have a lick of problems.
#24
It works fine with Win7 32bit for as far as I can tell. I've used it several times now and it works like a charm. The only weird thing is that it asks to put in a disk in my a: 3,5" drive but I already mentioned that. It doesn't make any difference though... Still works great!
#25
it also should only happen when trashing the databases. if you just do the prefs or app data you should not see it if you do everything or just the databases you should see it. thanx
#26
I think it had to do with something else.. It hasn't happened anymore. I've tried all options.
so just to be clear, it works perfectly! Thanks! |
#27
It works fine on my Win 7 32bit, PT8.0.1 rig.
Thanks, guitardom , it's very helpful and convenient. |
#28
Hi, thanks for the Trasher. It does work beautifully. I have LE8 on a WinXP SP3. I just would like to request for one thing if it were possible. When I press "p" to clean the plugins window, I get an error that reads that the program failed an attempt to launch. Then it closes. I believe it is due to my XP in Spanish. Therefore, there's no "Commom Files" thread but "Archivos Comunes". Can the code be fixed to include this path and complete its full functionality?
I don't know if I'm asking for too much, but anyway, thanks for even just reading this. All the best. You did a great job.
Take the red pill and I'll show you how deep the rabbit hole goes. |
#29
Careful scar, don't piss off the digi gods! lol
#30
i can't seem to download the Trasher app
Tech Support Utility Fail | audiogeekzine | Pro Tools M-Powered (Win) | 2 | 08-23-2010 07:20 PM |
Digi Tech utility launch message | Kirby B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-20-2009 02:12 AM |
Tech support utility in PT8 | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-26-2008 08:42 PM |
DIGI...Tech Support Utility error | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-22-2008 07:36 PM |
Tech support utility | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-04-2007 12:00 AM |
