  #31
Old 06-29-2019, 08:01 PM
BScout BScout is offline
Default Re: Mojave breaks DADman software
Check your colour settings
Compatibility
DADman Software v5.3.3 Workstation Compatibility:
Mojave (10.14), High Sierra (10.13), Sierra (10.12), El Capitan (10.11), Yosemite (10.10). Not supported on Mavericks (10.9)
Note that a Windows release is still forthcoming
EuControl 3.5 or higher
S6 WSControl 3.5 or higher
Special note for macOS Mojave (10.14) users
If you experience problems with the graphic user interface (GUI) of DADman on macOS Mojave (10.14), such as problems with metering, confirm that you are using the default color profile for your Display and your computer. If you are using the default color profile and still experience problems, set the Color profile (System Preferences > Display) to one of the following:
sRGB IEC 699106-21
General RGB
http://avid.force.com/pkb/articles/e...s-MTRX-Support
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
  #32
Old 06-30-2019, 03:24 AM
Mr Base Mr Base is offline
Thank you ver much, you are the man!!
The issue has been resolved DADman running like a champ at 4K 60.
I appreciate the help big time, finally this Mojave nightmare is over!!
Base
  #33
Old 06-30-2019, 04:32 AM
paulo m's Avatar
paulo m paulo m is offline
Originally Posted by BScout View Post
Both. Firmware for all DAD/MTRX are now one file.
OK, I´ll check it on Monday, was just looking for the DADman update and didn´t noticed the MTRX firmware. Thanks for the reminder.
Regards,
Paulo M
  #34
Old 06-30-2019, 05:49 AM
paulo m's Avatar
I´ll be trying that, as DADman GUI doesn´t work on the iMAC Pro display and it works on our second and third external HP displays which are also 4K.
I´m under the impression that this DADman version is a beta, the version name ends with a "b" an on the installer menu in small letters was written" to be updated"...
Regards,
Paulo M
  #35
Old 06-30-2019, 07:04 AM
You would be wrong. “b” is for “build”; a sometimes standard practice in compiling software.
  #36
Old 07-01-2019, 08:16 AM
paulo m's Avatar
And usually also followed by a number...by the way, how to you know if it´s not a beta?
Regards,
Paulo M
  #37
Old 07-01-2019, 10:39 AM
Because the software is literally called: "5.3.3 build 2b"
And they've used the same naming scheme before.
Betas also aren't released to the public. Which is why they are "betas."
  #38
Old 07-02-2019, 06:44 AM
paulo m's Avatar
What I meant was that it could be a not completely finished version, just released due to customer pressure. Taking into consideration the color profiles issue and that it mentioned "to be updated" in the installer.
I know betas are not released to the public, I´ve been a beta tester for years. You would be surprised how many betas are released with an official name though....
Regards,
Paulo M
  #39
Old 07-03-2019, 01:36 AM
Have to say, it'd be real nice if DADman worked with non-default colour profiles. I have my display's white point calibrated to D50 as it's a lot easier on the eyes (otherwise I feel like I'm at a gas station).
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
DADman/PROmon on MTRX with OSX above 10.12 Sierra paulo m Pro Tools HDX & HD Native Systems (Mac) 4 03-01-2019 04:05 PM
Mojave ? Riquier macOS 89 02-26-2019 06:41 PM
MTRX Reference (Ref) Button in DADman Software jb_trm Pro Tools HDX & HD Native Systems (Mac) 4 02-20-2019 06:53 PM
Sum and Intercancel between MTRX DADman and S6 laki Pro Tools | S6 1 12-27-2017 04:18 PM
