CMOS checksum error defaults loaded
I 've perform a dis re-image on a cm408T module and still have this problem at startup: "CMOS checksum error defaults loaded". If I press f1 the fader module boot up correctly. I tried to save the bios settings with F10 but it doesn't work. I always have to hit F1 on an keyboard attached to the 408 to boot it correctly. Am I wright to think the CMOS battery should be change? Is there a link to a document to locate and access the cmos battery? Thank you!
Serge Hamel Mixer / Sound Designer http://www.netpostproduction.com http://immersivesoundvr.com/ |
Re: CMOS checksum error defaults loaded
Hi Serge,
This does sound like a dead CMOS battery. The battery is a CR2032 which should be available locally. The battery is located on the main SBC (the motherboard attached to the panel behind the display). Hopefully we can get a how-to document uploaded later today. I'll post a link once it's available. |
Great. thanks H.G.
Here's a link to the battery replacement procedure with photo:
http://avid.force.com/pkb/articles/e...ry-Replacement |
Thank you so much H.G. for the great support. It is really appreciated.
FATAL ERROR Xpand Was Not Loaded... | tomhartman | Pro Tools HDX & HD Native Systems (Mac) | 0 | 08-04-2012 07:02 PM |
Bad Bios Checksum is bad :( | Hotcrazyfruit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-01-2010 12:19 PM |
i need help with a DAE loaded error !!! | asweeney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-29-2007 06:14 PM |
Should I disable "Video BIOS Shadow" in CMOS? | rlcowa@work2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-11-2003 09:33 AM |
How to run CMOS setup program | Joz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-27-2003 09:03 PM |
