Why do G4\'s and Type 1 errors go hand in hand?
We have 3 G4's, all AV systems running 5.1.1, OS 9.1 or greater, at least 512Mb RAM, and each one of them has a Type 1 error when starting it's first session of the day. Every Day. It doesn't happpen on our 2 9600 AV systems. It doesn't matter if the drives are fragmented or not, because it happens even after I use Disk Warrior and Disk Doctor and Speed Disk and TechTool Pro. It doesn't matter if I've trashed preferences. So what's the deal? I would really appreciate some feedback from Digi on this one. Thanks.
Ninja Bob Hothead NYC |
Re: Why do G4\'s and Type 1 errors go hand in hand?
How do you resolve the error: do you simply click "OK" and relaunch Pro Tools or do you restart (warm boot) the computer?
If the latter, is it assumed then that this only happens after you power on the system? -Make sure that you Minimum memory values are at default for both PT and DAE. -Do you still get the same error if you launch Pro Tools from its application icon and then use the File>Open Session command? -Which drive in your system holds the authorization for PTAV? Based on this AnswerBase Entry it is possible that your system is having issues finding the authorization on your system(s). -In the meantime, create a Mac OS Base+Digi+OMS extension set and see if anything changes. Brent |
I keep getting this also with my New 192 Digital.
OS 9.2.2 PT 5.3.1 (allocated 150 MB) QS G4/733 1.2GB RAM This is a fresh install too. nothing but Mac stuff, PT and OMS. Strange! I did some research and a Error of Type 1 is a Bus Error. Digi, please clue us in on this.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K Protools 2018.10 HD Native in 1 project suite Eristopher Music |
Hi Brent, thanks for the reply.
Hopefully this will twig something and get us on the right track to make it stop happening. Thanks again Brent!
To eliminate the possibility of the copy protection causing problems, go ahead and deauthorize AVOption with the floppy and then reauthorize the drive. In addition, make sure the USB Floppy Enabler v2.1.2 is installed and included in your active extension set.
If that doesn't help, please post your slot order of both the Mac and your Chassis. Brent |
Hey Brent.
I de-authorized and re-authorized the AV options of the G4's, as well as installing USB Floppy Enabler v2.1.2. and trashing prefs. So far so good. I'll post my observations. Thanks!
good job Brent [img]images/icons/smile.gif[/img]
Hi Brent, I have experienced the same problem - having to boot twice to launch a protools session. (10 days now).. Power up-Start up, launch protools from the system drive, try to open a session (OPEN), and it crashes when finding the "insert" "plug-in" on the last few tracks...Hard re-boot. It works for most of the day. System is: G4 933, OS 9.2.2, OMF, Atto express dual, Storcase/Kingston hot swaps.
Is there any way that you can publish a complete list of 'extensions' for Mac OS that are necessary, and those that cause known problems..? Can you publish a complete Mac 'configuration' ;ie; memory, monitors, extensions, preferences, for the newest 192 HD..? -and older systems..? The tech documents available on the new HD 192 do not list the I/O Setup for the D/A expansion card..in the pin-out configuration (DB-25 connector) for analog output. (I/O Setup Pull-down selection). How many watts does a 192 HD consume? (UPS requires..) Why does the Output DB-25 say "Do not connect unbalanced loads - with the "LO"-pin connected?... Docs, docs, and more documentation could be extemely useful. It would be extremely helpful if Digi had a useful search engine on the DUC topics and the web site because some of this information is already here - j Anyway, we get it to work somehow. Thanks. |
003 PT LE 8 Automation by Hand? | SREMAC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-13-2010 08:28 AM |
Second hand G5 for Pro Tools HD 7.4.2 | axiom07 | Pro Tools TDM Systems (Mac) | 9 | 10-02-2008 03:50 PM |
Second Hand | Willosy | General Discussion | 2 | 07-10-2007 12:14 AM |
Second-Hand TDM | Jenre | Pro Tools TDM Systems (Win) | 4 | 09-23-2005 06:36 AM |
which TDM system available 2nd hand OK with G5? | martian | Pro Tools TDM Systems (Mac) | 0 | 02-07-2004 10:33 PM |
