help - tracks too hot !!! (technical questions)
Hi all, I have an M-Powered mix that's a little too hot. The sound is killer though, I don't want to lose it. So I have a few technical questions, probably y'all run into this "all the time" and I'd be very grateful if you could help a newb...
Question: when a track clips (indicator goes red), and then that track is recorded onto another track (via a bus), I notice that the bounced track does not clip (indicator does not turn red). What is happening here? Is the software simply "cutting off" the upper level at 0, or is there some kind of "soft limiting" going on (this is M-Powered 7.3)? Or is there something else, some other algorithm of some sort? Hardware action? What's up with this? When I bounce a track this way, am I to expect that the result will sound exactly the same as the original? In other words, is the playback process doing the same thing as the recording process (clipping, or soft-limiting, or whatever), so it is merely the indicator which turns red even though the actual output level never exceeds 0 dB? Or does the output level go as high as the meter (+6 or +12, depending on which version)? And finally, what is the suggested way of dealing with "too hot" tracks? This is pretty close to a final mix, could I use some kind of mastering tool like a brick-wall limiter or something? Or should I just record the track and be done with it? What other tools are available? I've heard of "tape saturation" plug-ins, are they any good? Will they do what I want? (I want my stuff "not to clip" and not to have any of that harsh nasty digital distortion). Thanks very much for your input. :) |
Re: help - tracks too hot !!! (technical questions)
Here is a great article on Mixing ITB by a great engineer:
http://www.popmusic.dk/download/pdf/...ital-audio.pdf Pretty much, turn your tracks down. Select them all an move them down by the same amount. I use the TL Mastermeter on my master fader set for -3db, and mix no hotter than that. It gives good headroom for mastering and you will find your mixes have a lot more depth and clarity. No need to push it hard all the time.
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM Windows 7 64-bit Pro Tools M-Powered 8.0.4cs2 M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1} Glyph 050Q 500GB via eSATA |
Read through this too, for when you're ready to send mixes out for mastering:
http://www.onlinemastering.dk/pdf/mi...ering-tips.pdf
HD3 to HDX upgrade availability and a few technical questions | vudoo | Pro Tools 10 | 0 | 10-24-2011 02:43 PM |
some technical questions | John Lindeman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-04-2005 08:46 AM |
Technical Questions | Wyn | ICON & C|24 | 3 | 11-10-2003 04:20 AM |
Mobo Upgrade Technical Questions | August Heat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-07-2003 03:11 PM |
A couple of technical questions | dwkick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-23-2003 08:22 PM |
