Old 07-06-2011, 05:39 PM
akaidai akaidai is offline
Default Mpowered 7.4 and compatible issue
recently my 1814 breakdown and i m left with only Producer Usb mic for the interface of my travelling laptop..can i used this mic as a soundcard for the mpowered 7.4?....thanx
Old 07-07-2011, 09:54 AM
scenicrecords scenicrecords is offline
Default Re: Mpowered 7.4 and compatible issue
I don't think so. See this link.
Pro Tools M-Powered 7.4, compatible M-Audio devices and drivers
Dell Studio 1555 Laptop, Intel Core Duo T6600 2.2GHz, 4GB RAM
Windows 7 64-bit
Pro Tools M-Powered 8.0.4cs2
M-Audio Firewire 410 via Digi-Qualified SIIG FireWire 2-Port ExpressCard {NN-EC2012-S1}
Glyph 050Q 500GB via eSATA
Old 07-27-2011, 06:43 PM
fre fre is offline
I've got one doubt regarding Pro Tools comaptibility with some hardware. I recently purchased a midisport uno interface in order to use it with PT M-Powered 7.4 and my electronic drumkit. However, once I launch PT a message appears on the screen telling me that no hardware device is connected. Is it possible that the midisport uno USB is not able to work as an interface to open Pro Tools? or is it me doing sth wrong?
My PC has windows vista SP2 32-bits.
Thank you so much for your help!!! Hope I have not thrown my money away by purchasing this and therefore have to buy another interface :S
Old 07-27-2011, 07:28 PM
First off, the Midisport UNO is not an audio interface. It is simply a MIDI interface. Second, click On the link in my post above to view compatible audio interfaces for use with Pro Tools 7.4. You didn't throw your money, away as the Midisport can be used in addition to a required audio interface.
Windows 7 64-bit
Old 07-27-2011, 08:13 PM
fre fre is offline
Yeah, certainly i did not waist my money but now I have to buy an audio interface, which I need in order to use the Midisport UNO and be able to record out of my electric drumkit, as you very well implied.
Thanks so much for your help!
Old 08-01-2011, 06:15 PM
fre fre is offline
Ok, I just found and audio interface, the M-Audio Micro. However, when checking on the link of compatibles audio interfaces, this one does not appear at all! Is there a slight chance that this link is not updated, because I am very interested in purchasing this audio interface to start working finally with my pro tools m-powered 7.4
Old 08-02-2011, 08:10 AM
That is not a compatible interface. Read the list. 7.4 is an older version that will only work with the interfaces on that list.
Windows 7 64-bit
Old 08-02-2011, 05:03 PM
fre fre is offline
Ok, thank you so much for that info!!!
Old 08-03-2011, 08:58 AM
RichrdC RichrdC is offline
I don't know how much interface you need, but the Project Mix I/O has been everything I've needed..
Old 08-03-2011, 11:48 AM
fre fre is offline
Thanks but I just need something simple and not so expensive. The JamLab I think is perfect for me. I just want to record some midi audio from my electronic drumkit, and I think the one you just recommended me is for much bigger projects
Crossgrade from mpowered to pro tools 9 - Recorded songs playback issue Mike1005 Windows 1 12-07-2012 01:09 PM
BFD2 issue with nuendo and pt mpowered 7.4 martin coria Pro Tools M-Powered (Win) 0 12-02-2010 03:17 PM
Mpowered 8.1, profire 2626, Clock issue nickomatiz Pro Tools M-Powered (Mac) 2 09-23-2010 02:20 AM
mpowered compatible computer help... nutrinoland Pro Tools M-Powered (Win) 11 11-17-2009 03:55 AM
7.3 mpowered update issue godzflava71 Pro Tools M-Powered (Win) 3 03-06-2007 07:18 AM
