Old 02-15-2016, 06:01 PM
Dave Clarke Dave Clarke is offline
Default "Can't locate hardware" error
I have PT 9.0.6 and Mbox 3 running on Windows 9. Mbox control panel connects fine.
Pro Tools 9 appears to start loading (i.e. iLok OK), but once DAE loaded I get the dreaded "Can't locate hardware" error message. I have already uninstalled and reinstalled twice. This involves loading from original disc, and then applying 9.0.6 update.
I had been using it on this HP EliteBook HP8540w for a few months. It did seem to work OK, although sometimes I had to make sure to plug it into the right USB slot.
One other thing: Windows 7 never starts if the Mbox is plugged in when booting.
Any ideas on how to troubleshoot this?
HP EliteBook 8540w
Windows 7 Service Pack 1
Pro Tools 9.0.6
MBox 3 (driver 1.0.22, firmware 1.0.8)
Old 02-16-2016, 06:33 PM
Default Re: "Can't locate hardware" error
I uninstalled iLok and PT completely, then reinstalled up to 9.05.
Things were even worse - now PT would exit silently after a few seconds without even an error message.
I decided to try 9.06 update. I also cleaned up the start up and services (I have a separate user for ProTools with Admin privileges with optimized configuration per PT recommendations).
I found what appeared to be a duplicate but identical entries in the registry for Avid MME. So I disabled one of these.
And now it works!
HP EliteBook 8540w
Pro Tools 9.0.6
Old 01-15-2018, 06:08 PM
therealwilllove therealwilllove is offline
Default Serious help
I HAVE MBOX 2 AND THE DRIVER SHOWS HADWARE NOT CONNECTED ON PRO TOOLS LE 8.5 RUNNING WINDOWS 7 BUT IT RECORDS FINE IN PRO TOOLS BUT SHOWS NOT CONNECTED IN THE CONTROL PANEL OF THE MBOX
Old 01-17-2018, 09:08 AM
Default Re: Serious help
Start a new thread. Describe your problem and include the following:
What have you tried?
What hardware is connected(whether interface or not)?
Complete details on the computer(a sisoft "Sandra Lite" report is ideal)
DO NOT USE CAPS LOCK(thank you very much)
Old 01-17-2018, 11:06 AM
i dont know how to start a new thread read the instructions still cant find it
Old 01-17-2018, 11:10 AM
Southsidemusic's Avatar
Everything is well explained here:
http://duc.avid.com/showthread.php?t=81323
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 01-17-2018, 11:11 AM
thanks
Old 01-23-2018, 05:32 AM
coreyrhys833 coreyrhys833 is offline
can some one help me please, I downloaded pro tools express with the mbox mini.. and it was coming up with cannot locate hardware then I eventually got it sorted then I unplugged it plugged it back in and its saying cannot find hardware again, I'm confused ive tried uninstalling and re installing but its not working thanks
[IMG] code is Off
"Unable to locate hardware.." Error w/ ProTools 10.3.2 vanthemon11 Eleven Rack 1 01-27-2015 02:04 PM
PT 10 HD Error: "Unable to locate hardware....." Jay Terrien Windows 4 08-12-2012 11:48 PM
Error "unable to locate hardware. make sure your hardware is connected and turned on" tmcgrechan Windows 2 10-06-2011 09:12 AM
Another "Unable to locate Digidesign hardware" error message Albers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 05-28-2011 11:12 AM
The dreaded "unable to locate digidesign hardware" error NZDingo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 11-09-2010 06:30 AM
