Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 01-23-2019, 04:29 PM
Hugh-H Hugh-H is offline
Default BUG - using N key for PB engine select with HDX cards installed
Hello,
There's a bug in the programming for using the N key to select the PT playback engine on startup. If you have HDX cards installed and no audio interface attached the following occurs -
- Using the N key has no effect, PT always boots to the HDX engine.
- Having no audio interfaces attached naturally PT doesn't come up, as expected.
- There's no way to select another audio interface with the HDX cards present.
Seems odd, I thought the N key method was the first thing PT looked for, apparently not. If the HDX cards are present they override the N key option.
Odd.
You may ask why anyone would do that. That's a separate question, suffice to say if there's an issue and you need to use something else, pulling the HDX cards is inconvenient.
Did I mention ODD?
Hugh
Old 01-23-2019, 08:03 PM
Default Re: BUG - using N key for PB engine select with HDX cards installed
What other interface are you trying to use? Its not possible to give too much info
Old 01-23-2019, 11:03 PM
YYR123's Avatar
YYR123 YYR123 is offline
Like ever?
I agree with Dave there isn’t enough info here to make a judgement as to how best to resolve the issue.
OS versión
other interfaces
What exactly you are trying to do
PT Version
Daniel
Old 01-24-2019, 09:09 AM
Hello,
Odd.
Did I mention ODD?
Hugh
Like the others said, need more info, but FWIW, 'N' key behaves as expected here (and on any other rig I've been on recently); I can always choose alternate interfaces by booting with it.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 01-24-2019, 10:15 AM
Hello,
Thanks for the responses, here is some more information.
- MP 5.1 / OS10.12.6
- PTHD(ultimate,greatest,etc.) 18.3
- HDX2, and normally SyncHD + 2x HDMadi attached
- System works correctly with everything attached.
- Alternate testing interface - PT Aggregate, RME UFX+, built-in, any, doesn't matter in this case.
Repro -
- Unplug the Digilink audio interfaces, in this case the two HDMadi and SyncHD units.
- Plug in any supported CoreAudio interface or use the built-in.
- Launch PT using N key.
- Usually N key works if pressed immediately. Test launching it with whatever timing you can. Immediately, incrementing 0.5 seconds after launching, at splash screen, etc.
- Result is always the same - PT sees the HDX cards in the system, ignores the N key, and comes up with the message similar to "... no audio interfaces connected..." and as expected will not launch.
The reason I care is if there's an "oddity" in a cpu/system I'd like to pull it, swap in another cpu immediately to continue work, bring the suspect one to the lab and test it. Many instances of testing, setup, and maintenance can be completed with any generic audio interface. In this case I needed to test some surround bussing and weirdness and an RME interface works well for that due to TotalMix's I/O meters, but again the audio interface in this issue doesn't matter.
Having to pull the HDX cards from the chassis is not timely, especially in a number of our Sonnet chassis systems that require some work to accomplish that.
Thanks again for any information you may have,
Sincerely,
Hugh
Old 01-25-2019, 04:56 AM
musicman691 musicman691 is online now
Hello,
Repro -
Sincerely,
Hugh
You need to hold down the 'n' key BEFORE you launch PT. Any other way won't work right. You appear to be doing it wrong.
Jack
QAPLA!
Old 01-25-2019, 07:38 AM
K Roche's Avatar
K Roche K Roche is offline
Yes the:
is likely the problem
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB, Radeon Pulse RX 580 8GB GDDR5 Dual HDMI Graphics Card..... OS- Mojave 10.14.6, and PTHDN 2019.6 on on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2nd Samsung 970 EVO 1 TB -- both in dual drive Crest I/O PCIE controller adaptor card
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 01-25-2019, 10:01 AM
Hello,
I think I tried that but not sure, I won't see the systems for another week or more but will test at that point.
Thanks,
Hugh
Old 02-08-2019, 05:16 PM
Hello,
I thought I had tried the N key before launch but wanted to be sure. I just received some systems back and gave it a try. Here still not working -
If HDX cards are installed and audio interfaces are not attached ProTools always gives the "... no audio interfaces connected...." error without the ability to change the playback engine, N key pressed or not at any time before or after launch.
Odd and makes troubleshooting more difficult.
Hugh
Old 02-08-2019, 06:17 PM
Hello,
Hugh
You have to hold down the 'n' key until PT fully launches
Jack
QAPLA!
Playback engine select grayed out Josh523 Pro Tools 12 1 04-11-2017 02:54 PM
No HD Native option in Playback Engine select ronstephens Pro Tools HDX & HD Native Systems (Mac) 9 07-02-2015 10:16 AM
PT11HD can't relaunch/select new playback engine sersol Windows 0 05-31-2014 05:31 PM
No sound coming from my 003, even when I select it as my playback engine. HELP ThrillHillStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-10-2012 12:03 PM
Cant select "1 processor" in Playback Engine Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-24-2008 03:38 PM
