Old 03-19-2021, 05:52 AM
Reckless Erik Reckless Erik is offline
Default Dante for Atmos
Anyone here using Dante as the input feed for the Atmos renderer (using MTRX/Studio)? I'm having a lot of CPU problems using the bridge (I guess the trashcan is not up to it) and I was wondering if it would be better to set up the renderer on a separate machine and link everything via Dante. Any thoughts?
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 03-19-2021, 10:41 PM
Mixchump Mixchump is offline
Default Re: Dante for Atmos
Yes, it seems that running the renderer on a separate machine via Dante or Ravenna (or MADI, or whatever) is best. The Bridge playback engine has some limitations for sure (forget about doing a last minute overdub, or hardware inserts, etc...).
The Send / Return plugin method is a no go (doesn't work with delay comp).
It seems that the only way that ProTools is able to calculate delay comp correctly is to have all of the paths to the renderer exit via actual output paths. Running a separate machine seems like the only way to guarantee that they work as intended...
Old 03-21-2021, 02:06 AM
kosmokrator kosmokrator is offline
Yes, we're running the Renderer on a separate MacMini, connected to the MTRX via Dante.
Do you have specific questions?
Old 03-21-2021, 08:03 PM
LDS LDS is offline
I had a bunch of issues with dolby audio bridge in larger sessions on my trash can. It would drop sync of some kind quite regularly, pushing the audio into aliasing. The renderer would also routinely drop out of record mode. I don't think I have ever managed to print a full master from start to finish without punch ins.
I've moved to using it via Dante from Pro Tools running through a DX32R, into a second computer running DVS and it is much smoother sailing.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 03-22-2021, 03:45 AM
Would you care to share your MTRX config for the routing? Also do you get 128 channels into and out of the renderer? Thanks Nick
[email protected]
Newcomer Audio Post
Old 03-26-2021, 03:29 AM
We have the additional DigiLink card for the MTRX to get 128 IO into PT.
Then, it's a matter of just routing the DigiLink INs to Dante OUTS and vice verse in DADMan.
Our routing wouldn't help you much since we're also using other IOs (MADI etc.).
Old 03-26-2021, 06:55 AM
Got it. Thanks anyway
[email protected]
Newcomer Audio Post
Old 03-26-2021, 07:04 AM
gives's Avatar
gives gives is offline
I was told to get an additional DigiLink cable, (two now), for a better connection.
I am running a Mac Pro Trash Can as well and everything seems to be working fine here. Jeff Komar, (Avid Project Specialist), might have some answers on this?
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Old 03-26-2021, 11:43 AM
Greg. Yes I also have both digilink ports connected to the HD Native box. Do run video off a separate drive to audio? Maybe that is what's slowing me down.
[email protected]
Newcomer Audio Post
Old 03-28-2021, 11:04 AM
tom_lowe tom_lowe is offline
If you're running off SSD or a fast NAS or RAID I see no reason to run from a separate drive, but it did used to be one of the first things to fix if you were getting issues. Mainly due to spinning drives being so slow.
HTML code is On
HDX with Dante Via freakhouse Pro Tools HDX & HD Native Systems (Mac) 38 09-18-2021 06:18 PM
DAPS out to Dante VS? Frank Kruse Post - Surround - Video 14 03-22-2020 02:27 AM
Ultimate-Dante or hdx-alone pov DetroitT Pro Tools HDX & HD Native Systems (Mac) 2 01-31-2020 08:09 AM
Sync HD and Dante?..... PT user Pro Tools HDX & HD Native Systems (Mac) 5 03-19-2018 11:24 AM
HD Native and Dante JCBigler Pro Tools HDX & HD Native Systems (Win) 11 12-10-2013 01:01 AM
