Protools 10 (Windows 7 64bit) Launch Issue
I just got Protools 10 today and its crashing upon launching. For a split second I can see that it would crash as soon as an AIR plugin would attempt to load.
So I tried to go to the plugins folder and removed all the AIR plugins (Which sucks). I did this just to see if it would work but no luck. It would freeze on any plugin loading. I even temporarily removed all my 3rd party plugins and that has nothing to do with the crashing issue. My computer is running off of Windows 7 Ultimate 64bit with service pack 1 like Avid recommends. I had ZERO issues with Protools 9 so even though I purchased Protools 10 I have to go back to version 9 because I have sessions to work on with clients tonight. PLEASE ADVISE US FOR ANY NEW TIPS TO FIX THIS ISSUE!!! Audio Interface: Digi002 RACK OS: Windows 7 Ultimate 64 bit Service Pack 1 Processor: Core i7 920 2.67 Memory: 6 X 2GB = 12GB RAM Internal Hard Drives: 500GB (C:) OS/Pro Tools/Plugins 2TB (D:) Protools Session Projects 1TB (E:) Library for sounds and finished songs Sandra Report: ----------------------------------- SiSoftware Sandra Computer Model : OEM System Product Name Workgroup : WORKGROUP Host Name : ABRStudio-PC User : ABR Studio Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.81GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : ASUS P6X58D PREMIUM BIOS : AMI (OEM) 0604 01/21/2010 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 12GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 536MHz (1.07GHz) Memory Module(s) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMD12GX3M6A1600C8 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.84GHz, 512MB DDR3 2.2GHz 256-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce 9800 GTX+ (128 SM4.0 1.84GHz, 512MB DDR3 2.2GHz 256-bit, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : NVIDIA GeForce 9800 GTX+ (128SP 1.84GHz, 512MB DDR3 2.2GHz 256-bit) Storage Devices WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) : 466GB (C:) WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:) Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) : 2TB (D:) TSSTcorp CDDVDW SH-S223L (3.9GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 4GB (F:) Logical Storage Devices System Reserved : 100MB (NTFS) Library (E:) : 932GB (NTFS) @ WDC WD1001FALS-00E8B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) Protools (D:) : 2TB (NTFS) @ Seagate ST32000641AS (2TB, SATA600, 3.5", 7200rpm) Hard Disk (C:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, 32MB Cache) PART 16 (F:) : 4GB (UDF) @ TSSTcorp CDDVDW SH-S223L (3.9GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS 88SE914D SATA-600 Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet) Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2 (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 5.9 Respectfully, Alex
Alex "Q-Dash" Medina CEO, ABR Productions LLC Audio Engineer Producer, Writer |
Re: Protools 10 (Windows 7 64bit) Launch Issue
Hey Alex, I guess you don't keep imagines or clones. Do you use partitions? Can you reinstall Windows? Did you only install Pro Tools 10?
Aaron Mulqueen - 001 HD Native |
Did you install PT10 over top of PT9?
It seems most of the people with issues didn't uninstall PT9 first. At the very least I would try uninstalling (CLEAN) and reinstalling.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
It doesnt allow you to install protools 10 over 9. So I had to uninstall protools 9 before anything. I also uninstalled my music production toolkit 2 that worked with protools 9 since I was reading it is not compatible (Which sucks cuz I just bought it last year).
It gave me the full version of structure which I liked enough to not want to get rid of it. But your right besides that. It was just the fact that i spent money on it for PT8 and since it was a recent purchase at that time AVID allowed me to use the virtual instruments for PT9 with an update.
NICE!! This is all i have on my iLok.
Product: Pro Tools 10 in bundle Pro Tools 10+9 Bundle Company: Digidesign Type: License Expiration: Never Date downloaded: 10/22/2011 Product: TL Space Native Company: Trillium Lane Labs Type: License Expiration: Never Date downloaded: 03/16/2010 Product: Eleven LE Company: Digidesign Type: License Expiration: Never Date downloaded: 03/16/2010 Product: Pro Tools MP3 Export Company: Digidesign Type: License Expiration: Never Date downloaded: 03/16/2010 Product: StructureContent LE Company: Digidesign Advanced Instrument Research Group Type: License Expiration: Never Date downloaded: 03/16/2010 Product: Structure LE Company: Digidesign Advanced Instrument Research Group Type: License Expiration: Never Date downloaded: 03/16/2010 Product: Smack! LE Company: Digidesign Type: License Expiration: Never Date downloaded: 03/16/2010 Product: Hybrid Company: Digidesign Advanced Instrument Research Group Type: License Expiration: Never Date downloaded: 03/16/2010 Product: Music Production Toolkit Company: Digidesign Type: License Expiration: Never Date downloaded: 03/16/2010 Product: Pro Tools 9 in bundle Pro Tools 10+9 Bundle Company: Digidesign Type: License Expiration: Never Date downloaded: 10/22/2011
MPKT offered Structure LE IIRC.
I can offer a tip that has worked for me.
1. Move all of your third party plug-ins into the disabled folder 2. Uninstall Pro Tools entirely including preferences 3. Make certain the plug-ins folder is empty 4. Reinstall Pro Tools 5. Launch Pro Tools for the first time without any plugs that it didn't just install 6. Move the rest of your plugs back into the plug-in folder
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Digi003 Driver issue?? + Windows 7 64bit | jouleskeys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-01-2011 05:20 PM |
protools 8.0.5 NOT WORK ON WINDOWS SEVEN 64bit | markolone | Pro Tools M-Powered (Win) | 8 | 04-30-2011 02:07 AM |
who use protools 8.0.4 on laptop with windows seven 64bit | markolone | Pro Tools M-Powered (Win) | 2 | 10-15-2010 01:27 PM |
Does Protools works on 64bit Windows?? | converted | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-14-2008 07:17 AM |
Mbox and ProTools 6.4 on 64Bit Windows? | EVERGLEAM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-27-2005 12:35 AM |
