Old 05-02-2009, 10:33 AM
Default Renaming Files by TC-Stamp
here´s what I´m looking for:
During an ADR-Session the recordist sometimes forgets to rename his recording track to the currect loop-number. Then after recording a few takes he notices his mistake and renames the track.
Most of the time there is no time to correct the error for the already recorded takes so I make a note that the first 4 takes were recorded under the number of the previous loop.
To clean up the mess later I was wondering if there´s a batch-renaming tool that can read the TC from inside a BWAV and rename all the files that have the same TC-IN to the same loop number.
Is there a trick to do this or will I have to keep on doing this manually?
Thanks,
Frank
Old 05-02-2009, 11:37 AM
smurfyou smurfyou is offline
Default Re: Renaming Files by TC-Stamp
Could you sort the region list by timecode, select your takes there, and do an auto-rename? I'm not in front of PT at the moment but I've done that in the past for a different situation.
Old 05-02-2009, 11:51 AM
Auto-rename doesn't work for file names. Only region names.
Maybe my task could be a cool feature to add to maggot's sibliminator:
Find files with same timestamp. Ask user for prefix then rename, number and give them a family-id. Can't change unique IDs otherwise the files will never link back to my session.
In the meantime I'm using soundminer. Sort by timestamp and then batchrename in admin-window.
Frank
Old 05-03-2009, 01:31 AM
The Cargo Cult's Avatar
The Cargo Cult The Cargo Cult is offline
The Cargo Cult
that might be a handy feature for sibliminator.
can't see myself opening that one up for a while tho I'm afraid.
auto-rename in PT can still be useful tho - you just need to batch-rename the regions, then shift-cmd-R rename them while they are still all selected in the regions list. then you just bash the ENTER key a bunch of times to apply the name to the file.
Old 05-03-2009, 04:19 AM
Thanks Justin,
I´ll try that.
Frank.
HTML code is On
How do I line files to curent time stamp? Mark 66 Post - Surround - Video 2 07-16-2006 01:46 AM
Renaming Files n3xus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-25-2005 01:12 AM
Lost files and renaming files GoneIndie Pro Tools TDM Systems (Mac) 2 01-13-2005 07:08 PM
Getting time stamp from DP3 SDII files? Nash BBQ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-20-2002 04:36 PM
Exporting files with timecode stamp daniel_c Tips & Tricks 1 01-13-2001 02:34 AM
