Old 10-09-2019, 11:44 AM
Mick Boggis Mick Boggis is offline
Default RTAS K Meter plug in
Hi, I have a mix to do in someone else's studio the day after tomorrow (late booking) The studio is Mac 10.8.5 Pro Tools 10 HD3. Does anyone know where I can download a K Meter plug in free / cheap ?
Old 10-09-2019, 01:11 PM
amagras amagras is offline
Default Re: RTAS K Meter plug in
I don't know if PT10 has it but right click on the Master channel let you select from a list of meters including the K system. If not then just use the trial of your favorite meter plugin
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 10-09-2019, 02:16 PM
Thanks for the reply - but ....obviously Pro Tools 10 does not have "a list of meters including the K system" and " just use the trial of your favorite meter plugin" is not an option as Pro Tools 10 is 32Bit RTAS therefore no current trial will come in that format.Thanks again and best regards.
Old 10-09-2019, 02:49 PM
It's not obvious, I don't know how knowledgeable you are and I haven't used my PT10 since 2015.
Do you have a VST bridge like Patchwork?
I don't know if this has what you are looking for but it's free and worth a try: https://youlean.co/youlean-loudness-meter/
Good luck
amagrasmusic.com
Old 10-09-2019, 06:14 PM
It is obvious...re Pro Tools 10 does not have "a list of meters including the K system". This was introduced in PT11. I also haven't used PT10 in a long time, as I stated in my original post "I have a mix to do in someone else's studio the day after tomorrow (late booking)".
Old 10-10-2019, 08:37 AM
Ben Jenssen's Avatar
https://www.meterplugs.com/kmeter
PT10 can use AAX if it's 32bit, and these guys offer just that in trial form.
Old 10-10-2019, 09:39 AM
Just the job, thank you Ben.
Old 10-10-2019, 11:57 AM
crizdee's Avatar
crizdee crizdee is offline
There are some others that are good and not expensive.
RTAS and AAX32...
Klanghelm VUMT
TC Electronic LM1n
TBProAudio meter 2 or meter XT
Chris
Producer, Engineer,
www.ukmastering.com
why external vu meter/ plug-in vu meter differ? sjtae macOS 8 06-06-2012 05:50 PM
CPU (RTAS) Meter yarrick19 Pro Tools 9 5 12-08-2010 02:23 PM
CPU (RTAS) meter bouncing around rhumphries Post - Surround - Video 2 10-07-2010 12:37 PM
-9128 error with 45% RTAS meter rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-26-2009 03:54 PM
RTAS Meter Creeping up when stopped BrownMan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-14-2008 09:32 AM
