Old 03-16-2021, 09:59 AM
TJ Allen TJ Allen is offline
Default 'Do To All' Soft key behaviour
Hey all,
I've just noticed some slightly unexpected behaviour with the Do To All Softkey (although it might be intended).
I'm setting up a handful of Automation Softkey commands on the Track Colour Buttons of the S1, and 'Do To All' seems to react the same as the 'Do To All One Time' mode, so instead of only acting when pressed in combination with another button press, it latches on until another command is used.
Is this intended behaviour? I can see how this might be beneficial for some users to allow for one-handed commands, but this seems to be what 'Do To All One Time' is for?
Cheers,
Tim
Old 03-23-2021, 04:59 AM
Default Re: 'Do To All' Soft key behaviour
Tiny bump.
Can anyone confirm or clarify this behaviour?
Thanks!
Tim
Old 03-23-2021, 06:16 AM
reichman's Avatar
reichman reichman is offline
Not sure. I stopped using the "Do To All" commands when I figured out that Alt-Touch, or Alt-Latch was faster and easier. Do To Selected can be achieved with Alt-Shift-Touch etc. But perhaps you have a different workflow goal.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-23-2021, 09:22 AM
Thanks Nathaniel - that’s a really good call.
I’m using it to quickly drop all faders into or out of Trim, or to reset all faders back to Read from whatever state they are in. Alt seems to work well combined with the Trim and Read softkeys and doesn’t have the problem of Do To All latching.
Ace! Thank you.
Tim
Soft Keys - System Soft Key Display Mode skilletaudio Avid S4/S6 0 09-25-2019 09:07 AM
PT 9 Strange behaviour Jeanpaul Windows 3 08-08-2011 05:09 AM
soft-limiter on mbox 3 soft-limiter.. overdriven tape saturation sound mjhann83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-07-2011 09:01 AM
7.2 new behaviour I don't like Dan Pinder Pro Tools TDM Systems (Mac) 4 08-14-2006 12:06 PM
What would be the perfect (Plugin, Soft Synth, Soft Sampler Library)? rtcstudio Pro Tools TDM Systems (Mac) 3 11-16-2002 07:57 PM
