Old 11-20-2020, 08:24 AM
EddieJones's Avatar
Default Re: EUCON 2020.11 Released
This App is a different code base to S6 so it wont be coming to it. We do have plans to make a standalone App of the Master meters on S6 we but don't have a date as there's a lot more stuff we want to get done first (Custom knobs, swap layer, single knob on MTM, customizable buttons on the Fader Module so that DSP, Copy, Paste, Free etc. can be added by users)
Old 11-24-2020, 07:49 AM
skilletaudio skilletaudio is offline
Originally Posted by EddieJones View Post
We have found a bug in the Master Module installer that requires an uninstall to work correctly. We'll fix for the next release, sorry for the hassle.
How do we get to the uninstaller window it seems to be hidden.
Old 11-24-2020, 08:26 AM
Those features sound fantastic, Super excited to get "single knob on MTM" to work in Pro Tools. I love that feature with Cubendo.
Old 11-24-2020, 09:18 PM
basehead617 basehead617 is offline
Just to clarify, the plans are so that you could have e.g. iPads replace the Display modules and have all their functionality? Or just metering?
Old 11-25-2020, 12:31 AM
kava kava is offline
uninstalling also did the trick for me, I was afraid of loosing settings, thats why I never uninstalled. but everything is back again.
a thought on the single knob on the mtm.
I am dreaming of something like a single "quick map knob"
There are a lot of plugin knobs i don't need very often, and searching for them on the surface or the mtm takes too much time - so I use the mouse.
If I could hoover with the mouse over a plugins knob and do right-click- "map to mtm knob until plugin window closed..." ....
best
thomas
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15
ProTools Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
  #16
Old 01-02-2021, 07:41 AM
Roger Stauss Roger Stauss is offline
Default Re: EUCON 2020.11.1 Released
Good morning and happy new year.
A couple questions for Eddie. I'm about to install 2020.11.
Should I wait for the Uninstaller bug fix first?
Should the S6 be disconnected from the workstation before updating the MM?
Thank you
Roger
  #17
Old 01-02-2021, 09:19 AM
EddieJones's Avatar
The installer bug is already fixed in 2020.11.1
It doesn't mater disconnecting as you should reboot everything anyway after.
  #18
Old 01-05-2021, 09:23 AM
Hi Eddie,
I successfully ran the uninstaller on the MM.v 2020.6 and installed 2020.11.1.10. I had to recover an authorization code from my account.
I have an older issue that involves the S6 display of wave forms. When tracking, the wave forms begin to loop after about 2 minutes into the session. The problem is intermittent even while working in the same session.
Specs: S6 running MM v2020.11.1, Windows 8, installed in 2016. Mac OS Catalina 10.15.7 on a 2013 8-core Mac Pro, 32g Ram, EuCon 4.7.4, WS Control 2020.11.1.10
Where can I find the uninstallers for WS and EuCon? Should I try that?
Thanks,
Roger
  #19
Old 01-05-2021, 09:56 AM
EddieJones's Avatar
The installer is also the uninstaller....see check boxes at the bottom for removing everything. But this issue can be caused by having the waveform scrolling to fast on both the S6 and PT. Can you zoom out a little and see if this fixes the issue?
  #20
Old 01-06-2021, 10:04 AM
Eddie,
I zoomed out from :30 to :60 on the S6. And that's working fine. The PT display has always been working well on the workstation.
I can post a couple videos to Drop Box showing the problem if it happens again.
Thanks.
Roger
EUCON 2020.11.1 Released EddieJones Avid S1, S3, Dock and Control App 4 01-06-2021 11:44 AM
EuCon 2020.11 ViciousLullabyz Avid S1, S3, Dock and Control App 44 12-09-2020 10:40 AM
EUCON 2020.11.1 Released EddieJones Artist Series 5 12-02-2020 11:53 AM
EUCON 20.6.1 released EddieJones Avid S4/S6 0 05-21-2020 10:30 AM
EUCON 20.1.0 Released EddieJones Artist Series 2 03-03-2020 07:31 AM
