Old 08-20-2018, 11:34 AM
jwilkers jwilkers is offline
Default Monitor not following to selected track when selecting on Pro Tools Control
Hi!
I may know the answer to this already, but here goes.
I have an Artist Mix and a Pro Tools dock working simultaneously.
Let's say I have 30 tracks and am viewing the first bank of 8 on Artist Mix with track 2 selected. All good. Track 2 is on screen and Pro Tools Dock has it selected.
Let's also say that I can only see 10 tracks in both Edit and Mix view. I know I can see more, but this is for an example.
If I choose track 29 from Pro Tools Control on the Dock, it selects track 29 but jumps off the screen and the same 8 tracks are shown selected by the Artist Mix.
If I Nudge or Bank the Artist Mix I can get there, but it seems to me that it should follow.
MackBook Pro
12.8
Sierra
All updated drivers and software for the two consoles.
Thanks!
Old 08-20-2018, 01:50 PM
BScout BScout is offline
Default Re: Monitor not following to selected track when selecting on Pro Tools Control
EuControl Settings>General>Auto-bank to selected track
However, I'm seeing a problem with it. It is working some of the time but not all of the time.
Old 08-21-2018, 06:23 AM
Thanks,
I appreciate your help.
I will try that.
Even if it works SOME of the time. it's better than what was happening.
Old 08-21-2018, 02:20 PM
Hmmmmm, already had that box checked. I suspect it's the Artist mix keeping control of the banks that it is set to regardless of which track you choose on the Dock.
Old 08-21-2018, 02:22 PM
I take that back. The Artist mix is banking to the correct position.
Old 08-22-2018, 07:29 AM
Checked every thread on this forum on the subject that I could find.
All boxes checked as suggested in EUCON settings and Pro Tools preferences.
Screen is still not following.
Old 08-22-2018, 11:45 AM
Screen following works perfectly here.
The bug I'm seeing is the Artist Mix will not bank correctly. Say with a session with 35 tracks, selecting 1-8, everything banks correctly but if I select 9, suddenly the Artist mix banks to the last 8 (tracks 28-35) in the session and the Control app shows the correct 2-9. Same for 10. Then I select track 11 and the Artist Mix goes back to doing things right (shows 11-18). And on screen, the tracks move to the selected track but when that "split" happens between Artist Mix and Control app track display, I see two separate blocks of tracks highlighted in blue (the indicator for what's on the surface.) I've also seen this two blocks of 8 suddenly get separated by on 4 tracks not on either "surface" so there doesn't seem to be an rhyme/reason why it sometimes suddenly maps out that way.
Old 08-23-2018, 07:40 PM
EddieJones's Avatar
We have fixed a number of banking issues in the next release (Q4) so hopefully, have this sorted.
Old 08-24-2018, 07:03 AM
Thanks Eddie.
Pro Tools as Click Track Rig DAW - Selecting Memory Locations via MIDI Help! riffn Pro Tools 2018 3 05-31-2018 11:19 AM
Selected track follows designated fader Avid Artist Control Goombot Artist Series 2 11-10-2017 04:51 PM
Automatic scroll to track selected in D-Control? oortone ICON & C|24 4 09-09-2016 01:36 AM
BUG? selecting midi track arms record for selected track browniespeaks Windows 40 06-10-2013 11:41 AM
MC Control follow selected track? thebeatless Artist Series 0 03-07-2011 10:14 PM
