Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 03-07-2011, 08:52 AM
Kafrifelle Kafrifelle is offline
Default PT 8 M-powered + M-Audio ProjectMix now working together
I am so frekken disappointed because I moved my Pro Tools 8.0 M-Powered and M-Audio ProjectMix I/O from my MacBook Pro 15in on Snow Leopard (with dual core and only 2gb RAM) to my brand new iMac 27 i5 QuadCore + 4gb of Ram and I can't seem to fully complete the installation and worse, my M-Audio ProjectMix I/O will let me plus instruments and hear them thru PT 8 but it is not automated anymore for some reason ...
What Am I doing wrong here ? I also have tons of errors 5000 saying that the plug-ins are not working when I start my PT 8 M-Powered ...
Anyone can guide me thru suicide or better yet have any advice for making this work as it did with my MBP ?
Thanks sincerely
Old 03-08-2011, 05:18 PM
tribedescribe tribedescribe is offline
Default Re: PT 8 M-powered + M-Audio ProjectMix now working together
did you use the migration assistant by any chance? Are you running 8.0.4cs2?
1.Do a clean uninstall of pro tools.
2. Install current drivers for project mix
3. install pro tools
Old 03-10-2011, 04:35 AM
Hello, no, This is the actual 8.0 Original DVD without any upgrade yet.
If I understand correctly, I would have to install the ProjectMix drivers first and then PT 8 M-Powered ?
UPDATE: Ok, I did install the whole thing again from a clean install PMix pilot first, then PT8 ... I still don't get automation (sliders moving) on my Control surface (it's indeed in ProTools mode too).
I thought that I would have this working easily, it seems I must be missing a step in configuration though. PT8 Opens fine and lets me create tracks and I can hear the instruments plugged in the PMix. I see that PT 8 sees the PMix as a hardware ....
UPDATE #2: I have now updated the PT8 to 8.0.3 still no automation between the ProjectMix and PT 8.0.3 :-(
UPDATE #3 I made it work ... I needed to enter the configuration and assign PMix into midi mode.
I am a little computer challenged, any help would be appreciate. My iMac is running on OSX 10,6,6 with plenty of RAM.
Anybody
Old 03-10-2011, 02:31 PM
I just realized you might not have the project mix set up correctly. Follow the steps below.
Make sure the ProjectMix is in Pro Tools mode - NOT HUI mode, which is only for other DAWs - then configure it in the Peripherals>MIDI Controllers window to enable the faders, etc.
Then inside pro tools go to preferences and set the following to:
Peripherals>MIDI Controllers :
#1: Type :HUI
Receive From: Project Mix, Control
Send To: Project Mix, Control
Good luck
Old 03-11-2011, 04:02 AM
Hi Tribedercribe,
That is exactly what fixed the problem.
When I re installed the new gear on to the new computer, I was under the impression that it would be an automated confid. I was wrong,
Thx for the help.
M-Powered 8 with M-audio Projectmix I/O billyoung51 Pro Tools M-Powered (Win) 1 10-22-2013 06:35 AM
i cant get the controls on m-audio projectmix i/o to work with my m powered protools picassocreations Pro Tools M-Powered (Mac) 2 06-03-2009 07:13 PM
ProjectMix I/O with PT M-Powered 7.4 gone mad!!! gagaproductions Pro Tools M-Powered (Win) 0 04-12-2008 01:35 PM
NEED HELP WITH PROJECTMIX I/0 AND M-POWERED 7.0 MIKEYP62 Pro Tools M-Powered (Win) 5 01-31-2006 01:59 PM
PT M-Powered 7 and M-Audio ProjectMix scnboston Pro Tools M-Powered (Win) 2 11-29-2005 05:57 PM
