Numeric Keypad
I'm just getting started with PT LE 002R for Windows.
Can't seem to make the Numeric Keypad initiate Play/RWD/Pause/Rec ???? I'm useing a hard wired keyboard. I can mark Memory locations w/ ENTER button, but viewing Memory Locations Ctrl+ 5 doesn't work either. I can't seem to find a good way to pause and resume playback from desired position without the numeric keypad. Q: Does the Numeric Keypad" only function with TDM systems??? My "F" Keys all seem to work, but nothing in the Numeric Keypad works. Thanks, Russ |
Re: Numeric Keypad
russrags ,
Make sure you select "Transport" mode in preferences, not "Classic" happy tooling,
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Re: Numeric Keypad
Thanks Lemix,
I've got "Transport" checked, but the Numeric Keypad still doesn't work !@#$%^& This is a new Logitech keyboard. Is it confirmed then that the Numeric Keypad functions are for LE systems as well as TDM ??? Any help will certainly be appreciated. Thanks, Russ |
Re: Numeric Keypad
Sorry to hear...
And yes, AFAIK it should function similarly. I use the shuttle lock frequently. Also numeric "3" to initiate recording.. Maybe some else can jump in... >>OH, do you have your "numlock" on in windows ?? cheers,
Re: Numeric Keypad
Thanks Lemix,
I don't see "Numeric Lock" in Windows. I do see something that says "1-9 on Numeric Keypad only", but it is greyed out. Under "Prefrences / Display ... I see Transport RecordLock. but it won't stay checked and I don't think that's what I'm looking for anyway. Thanks for taking the time though, Russ |
Re: Numeric Keypad
OK..
On most win keyboards the left, top most key on the numeric section is "Num Lock". It also should have an indicator light, just left to the "shift lock". Is it on ?? You can just press the corresponding key, or to make it a default>>enable in BIOS. This is for desktop systems though ! I don't know how a laptop would handle that... good luck,
Re: Numeric Keypad
Lemix,
Thank You for your help. Sometimes I feel sooooo Stupid. Your suggestion fixed everything including opening the Memory Location window Ctrl + 5. Have a Great day, Russ |
How do I nudge without a numeric keypad? | andy knowles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-25-2015 03:17 PM |
Numeric keypad. | the_dr38 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-14-2011 03:51 PM |
Numeric keypad | Pais_man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-04-2010 11:59 AM |
New MacBook Pro x'd numeric keypad | EllenF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-01-2010 01:37 PM |
Numeric Keypad | MFR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-24-2009 03:58 PM |
