Old 02-16-2018, 03:11 AM
drums77's Avatar
drums77 drums77 is offline
Default PT HD 2018.1 HDX and High Sierra on Mac Pro Westmere 3,33
Anyone use this configuration? Now I'm on Yosemite with HDX and 12.8.1.
Can I upgrade my maOS to High Sierra? Or is best to upgrade to Sierra?
Mac Pro (Mid 2010) Six Core 3.33GHz macOS 10.14.6 MSI Radeon RX 560
Pro Tools | HDX, HD I/O 16x16, HD I/O 8x8x8
Pro Tools Ultimate 2022.9
MacBook Pro (Mid 2012) i7 2.3GHz macOS 10.15.7
Pro Tools 2021.12
Apogee Duet
Old 02-16-2018, 08:06 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: PT HD 2018.1 HDX and High Sierra on Mac Pro Westmere 3,33
12 core 2.66 here. HD 2018.1 seems not as stable as 12.8.3 is HS.
Although I'll venture 2018.1 without clients.
HS is a completely different drive/file type which also requires a 5,1 Mac Pro firmware upgrade.
It also lends itself to SSD's although I've used Firecuda 7200 rpm hybrid drives as well.
Just keep in mind this is not your usual OS change.
Why the need for Yosemite (10.10.x) change?
Maybe start by trying HD 12.8.3 of Pro Tools. This is a solid version.
Old 02-21-2018, 07:45 AM
K Roche's Avatar
K Roche K Roche is online now
Not HDX but so far HDN on High Sierra ( 10.13 .2 ) and PT HD 2018.1.0 is working great
On mid 2010- 6 Core Westmere 333 with PCIe SSD as boot drive. (see sig line)
Be aware High Sierra uses and installs Apple's new APFS file system and it is not recommended for Hard Disk drives (may work, but read several articles that did not recommend it) So your boot drive (at least) should probably be an SSD
Also note 2018 is qualified for HS 10.13.2
And note to DetroitT I am curious because my Mid 2010 Mac 5,1 did not require a firmware upgrade ? Is your machine a Westmere
System :
Enjoy the Journey
.... Kev...
Old 02-21-2018, 09:41 AM
drums77's Avatar
Yes, my Mac Pro is a Westmere 3,33 Mid 2010 with Yosemite and SSD for boot. My idea is to upgrade to High Sierra and Install PT HD 2018.1.
The question is:
I make a backup with time machine and upgrade to High Sierra the current SSD or I buy a new SSD and I made a clean installation of HS?
Pro Tools 2021.12
Apogee Duet
Old 02-21-2018, 10:31 AM
K Roche's Avatar
The question is:
Well doing a clean install is the recommended method
I did when I got the SSD and went from Yosemite to Sierra.
I would think you could just do the backup. Then erase your current SSD then install PT
Also I remember somewhere it was recommended to install the HD Drivers before installing Pro Tools which is what I do
But this time I actually just trashed PT Preferences , installed HS over Sierra and then HD 2018 Drivers and then PTHD 2018 over
PTHD 12.8.2 And so far no problems
System :
Enjoy the Journey
.... Kev...
Old 02-24-2018, 12:16 PM
I had great experience with my clean install of High Sierra, but as soon as I ran a point update to macOS everything went unstable, so the jury is still out there...
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card Sutee Sangsareechon Pro Tools 2018 1 05-11-2019 04:48 PM
Pro Tools 2018.1.0 does not recognize AVID MBOX Pro under High Sierra 10.3.3 ... 2arabigo Pro Tools 2018 10 03-02-2018 02:07 PM
High Sierra 10.13.3 PT 2018.1? off the wall macOS 10 02-16-2018 08:25 AM
High Sierra jon9 Eleven Rack 0 11-16-2017 03:35 AM
12.8.2R2 on High Sierra TrentWilliams Pro Tools 12 3 10-21-2017 10:09 PM
