Old 11-15-2009, 10:31 AM
bradykrzemien bradykrzemien is offline
Default Session keeps freezing on opening when it is "Restoring Audio Engine Settings"
Okay guys i got a new computer and external hardrive all optimized for audio production
for my first time opening pro tools everday i will get this 1115 error , but that only happends the first time i open pro tools, but it allows me to open it right after..
so i am trying to make sure everything runs smoothly before i throw all my audio files on my new external drive..
i just loaded PT 7.4 for xp .
my new computer has 3 drives, one system drive , for audio and one sample drive, i took one of my pro tools session folder, "one of my songs " and moved one to my external drive and one on my audio drive ,but it doesnt matter where i try opening it , it still freezes when saying
this is my new computer with the specs
http://pro-audio.musiciansfriend.com...ter?sku=620703
and this is my external hardrive ,
http://pro-audio.musiciansfriend.com...ive?sku=240563
any help would be greatly appreciated !
i can't stand pro tools anymore , i have spent Thousands of dollars trying to make it work PROPERLY , like WTF !!!! i am starting to lose hope in it. i am sooo close to ditching pro tools cause of all the problems .. F.U.C.K!!
someone help me !!!!
Old 11-15-2009, 02:02 PM
sw rec sw rec is offline
Default Re: Session keeps freezing on opening when it is "Restoring Audio Engine Settings"
Your links don't work.....
Old 11-15-2009, 02:16 PM
thanks ,
I Updated the links !
Any thoughts guys ??
Old 11-15-2009, 02:19 PM
How do you have your Glyph hooked up?
Also make sure there are no cd's in your drive...mine hung on "initializing databases" the other day 'cause I had a cd in the tray. odd.
Old 11-16-2009, 12:20 PM
its hooked up to firewire 400 ,
and no there was no cd in it .
Old 11-17-2009, 09:13 AM
Bump ,,,
anyone have any ideas ????
Old 11-17-2009, 09:58 AM
TCM's Avatar
TCM TCM is offline
Did you check some of these answers??
http://www.digidesign.com/index.cfm?query=1115
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 11-18-2009, 09:18 AM
okay there are a lot of things to choose from that could be the problem ,,, i followed this
"DAE -6096 or DAE -1115, FireWire communication problems.
On some Windows XP computers, if a DAE error -6096 or -1115 occur, or you experience random communication problems between Digi 002 and Pro Tools, try disabling "PCI to DRAM prefetch" in the BIOS Setup utility.
This can be found in the BIOS > Advanced > Chip configuration "
but in my bios , advanced setting , there is NO chip configuration option , could it be called something else..
Still trying and still confused !
Anyone??!?!?!
PT 10.3 Freezes When "Restoring Audio Playlists" ktuulu Windows 9 06-14-2016 09:57 PM
Pro Tools freezes - "restoring audio playlists" aldersyde Pro Tools 10 6 05-13-2014 03:40 PM
Import session data... please break out "plug in settings" and "plug in automation" yeloocevad Pro Tools TDM Systems (Mac) 19 10-05-2011 01:04 PM
Profire 610 + PT9.0.5 on HP DV7 Win7+64 "Crash" at Restoring Audio Settings **HELP** ozbirko Windows 2 09-14-2011 12:23 AM
PT6 Digi001 Playback Engine Settings don't "stick" wcody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-05-2003 09:44 AM
