Old 10-10-2009, 02:51 AM
STL Audio STL Audio is offline
Default Does adding a 2nd Process card increase tracks/voices?
Hi guys,
I have 1 x Core & Process card giving 128 Voices/tracks.
If I buy another Process card is this going to give me another 34 tracks/voices?
The difference between a core and the core + process is 96 to 128.
Could I keep doing this to the max 196?
Cheers TK.
Old 10-10-2009, 03:04 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Does adding a 2nd Process card increase tracks/voices?
Originally Posted by STL Audio View Post
Hi guys,
Cheers TK.
Pro Tools|HD 2 and Pro Tools|HD 3 systems provide up to:
• 128 tracks at 44.1 or 48 kHz
• 64 tracks at 88.2 or 96 kHz
• 24 tracks at 176.4 or 192 kHz
Producer, Engineer,
www.ukmastering.com
Old 10-10-2009, 03:10 AM
So is the answer no?, I have reached the maximum i can get with adding process cards?
What would me my count if I had:
1 core 2 process cards
or
1 core 1 process 1 accel
Old 10-10-2009, 03:32 AM
crizdee's Avatar
or
i think an accel card would give you the max 192 but i'm not totally sure, but it would give you more, and at least 140-160 i guess.
Must be on the digi site somewhere!!
Producer, Engineer,
www.ukmastering.com
Old 10-11-2009, 06:34 PM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Adding an accel should get you to 192 voices, up to 256 tracks. I don't know if you can get past 128 voices using just process cards or not.
Your card order with this setup should be Core, Accel, Process card.
Need ADMIN privileges to increase Voices / Playback Engine? mu-tron-kid Pro Tools TDM Systems (Mac) 1 03-03-2011 01:41 PM
Will adding an Accel card to an HD3 system give me more voices? WildHoney Pro Tools TDM Systems (Mac) 2 03-02-2011 05:30 PM
PT HD2 voices (process card) dan000 Pro Tools 9 1 11-06-2010 11:15 AM
Trouble adding 2nd process card to HD system. misterphoneman Pro Tools TDM Systems (Mac) 4 05-27-2007 04:17 PM
Increase No Of Voices Funkstar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-19-2004 01:11 PM
