What are the differences between a process card and an accel card?
Hi I want to know what are the differences between both cards and why the process card is out of business today.
Re: What are the differences between a process card and an accel card?
The quick answer... Accel has some more powerful chips and enables more plugins! almost 2x as many plugs as the process card. depends somewhat on which plugs, most have been maxxed for accel. also some plugins will only run on accel cards.
I heard swapping an Accel card for a regular Process card in an HD3 system gives only about a 15% increase in total system processing power. I have a Core, 1 Accel and 1 Process card. I thought about swapping out my 2nd process card but never had, because the benefit to the system doesn't seem worth it.
Bobby Peru Milwaukee, WI |
So why digidesign manufactured the process card instead of the accel card since the begining of the hd, the protools 6.1 runs with process cards and the 6.4 with accels cards, there is not so much time from 6.1 to 6.4 so why not manufactured the accel cards at the begining????
Availability of the more powerful chip (and the cheaper cost). That and the fact that HD has been around since OS9 and PT5.3.1.
As to the original question, I don't think it's worth the money. I did the same upgrade for a client to 2xAccel cards and he couldn't tell the difference. Unless you have money to burn stick with 1 of each. I have a non-Accel HD3 system and am very happy with it. |
IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Adding an Accel card to my HD2 made a world of difference. SB |
I have an HD 7 Accel PCI (1 HD Core + 6 HD Accel) in a 64 bit 7 slot PCI expansion chassis, from time to time it gets maxed out (96 audio tracks, 44,1 kHz, 3 to 4 TDM plug-in's on each track)
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
Process Card Question... Accel vs non Accel | gsilbers | Pro Tools TDM Systems (Mac) | 13 | 05-22-2013 01:51 PM |
Difference between accel card and process card? | MX582 | Pro Tools TDM Systems (Mac) | 10 | 08-11-2010 08:29 AM |
TDM Process and Accel Card Differences | Keith Moore | Pro Tools TDM Systems (Mac) | 1 | 04-23-2007 06:35 PM |
HD Process card vs. Accel card | Eric Seaberg | Pro Tools TDM Systems (Mac) | 1 | 09-10-2004 01:29 PM |
Accel card with HD Process card | Jazzbass56 | Pro Tools TDM Systems (Mac) | 7 | 07-22-2004 11:54 PM |
