Old 02-24-2005, 02:04 AM
melen melen is offline
Default MBOX PB : USB LIGHT OFF _ mbox freezes_ WinXP
Hi all !
Pb with mbox under winxp pro sp1 / last asio & wave drivers. The usb light is off (at start up & under win) and the mbox is set as an unknown usb device - not audio. I can not run the firmware updater (even when I try to update the driver of the unknown usb device).
I've uninstalled then try to reinstall all the drivers, but the install cannot find the hardware. I've tried to install the mbox on 2 others PC (win xp home & pro) but still the same problem. Maybe the mbox needs a physical reset or something like that ? Maybe it's dead...
Thanx
Old 02-24-2005, 03:59 AM
·[-_-]· Richon ·[-_-]·  Richon is offline
Default Re: MBOX PB : USB LIGHT OFF _ mbox freezes_ WinXP
(I hope you don't kill me after what i would say)
I read that you did install all the drivers...but , did you install PRO-TOOLS??????
Powerbook 12" 1,5Ghz 1,25Gb RAM
M-Box v.1.0 "the old one"
PTLE 7.0 Tiger(10.4.6)
Ministack v2 NEWERTECH FIREWIRE+SEAGATE 320Gb
Old 02-24-2005, 07:26 AM
No I won't !!!
Sure, but when I run it, it does not find the hardware. Only the two mic leds are on & i cannot switch them.
Old 02-24-2005, 08:44 AM
Bazzle Bazzle is offline
Have you tried with a different USB cable?
Bazzle
Old 02-24-2005, 08:54 AM
DigiTechSupt's Avatar
Has your Mbox worked in the past? If you can't get the driver/USB LED working on any of 3 different computers then it's possible there is a hardware failure and the Mbox requires repair. Please do try a different USB cable if you haven't already.
regards,
Digidesign Technical Support
Avid Audio Tech Support
Support FAQ
Old 03-01-2005, 05:09 AM
Thanx for your replies ! Yes I've tried another usb cable (same problem), and yes it's already worked in the past... And... yes, I think it's an hardware failure... Is there any reset of any kind on or in the mbox ? Thanx
Old 03-01-2005, 11:20 AM
There is no reset for this. Contact Tech Support for service options.
regards,
Support FAQ
Just bought a Mbox 2 mini, usb light doesnt light up/installation stops progressing? DjRybe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-27-2009 05:55 PM
Mbox 2's Light Doesn't light up and protools shuts me off Adam Mason 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-17-2007 01:40 PM
SETUP HELP! (WinXP SP2/MBox/USB) sfields@gt.com Pro Tools M-Powered (Win) 1 01-01-2006 05:33 PM
mBox(winXP) won't fid hardware,, mike u 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-16-2003 12:48 AM
Mbox for WinXP - when??? Cathexis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-10-2002 02:11 AM
