Old 05-15-2019, 05:20 PM
Toronto Paul Toronto Paul is offline
Default Need help patching Behringer XR18
Greeting Protools Jedi, I'll try and stuff as much info into this post.
I'm just moving to Protools from LogicX and am having an issue getting things up and running with the hardware in my basement rehearsal room.
The flowcharts look like this: https://photos.app.goo.gl/Bh7kSNY6AW8ssGVm8
I have the XR18 connected to a macbook via USB.
I have a Mackie Control Universal Pro connected to the XR18 via MIDI
The XR18 sends back to P16 monitor mixers via it's "ultranet".
I control the XR18 via iPad app.
I use the Mackie Control to control LogicX (now Protools)
What I want to do is:
Record 18 tracks from the XR18 into Protools
Playback 18 tracks from Protools back to the XR18
Use the Mackie Control to roll/playback/scrub Protools.
With Logic I was able to patch each rail for input XR18 1-18 and XR18 output 1-8. This way I could play back the multitrack files (flip the source on the mixer from LINE IN to USB) and practice against the band similar to a virtual soundcheck.
So far I've gone into SETUP\HARDWARE and the XR18 is in there. When I go into SETUP APP and the XR18 is in there with 18 inputs and outputs. I open the ProTools Aggregate and unchecked the built in microphone and output (just guessing at that).
I've gone into I/O Setup and both the input and output are showing the 18 channel cascade.
So far I can record all 18 tracks in Protools but when I playback they are mixing down and returning 1-2. <facepalm>
I've included the flowchart of the stereo workstation that I would mix any recordings. I'm not sure if there is one setup that would let me move projects from one room to the other without having to repatch by hand.
Could anyone enlighten me to what I've overlooked? I can't find anything in the Lynda.com lessons or Youtube.
Much thanks in advance.
Old 05-16-2019, 09:54 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Need help patching Behringer XR18
Each channel has both input and output assignments. The default for the channels is stereo 1-2. You will have to assign each track to the output you desire. If you only see two outputs, then you will need to go into the I/O setup and assign your outputs in PT.
Will
System Details
Old 05-16-2019, 11:46 AM
Alright, I found the problem.
I've kept the output in the IO section of each channel strip as the Stereo output but added an "A" send to every channel coming in from the mixer and set it to bus 1-16. Now during playback the mixer is getting all the tracks back on the same rails.
Setting up with Behringer XR18 Interface Jamiesjammin Pro Tools 12 6 11-15-2017 07:03 AM
patching and routing Cat 43 (and the like) jeremiahmoore Post - Surround - Video 1 08-26-2010 04:11 AM
Patching a RNC into a Digi001 bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-01-2006 02:29 PM
behringer mx9000,behringer mx3282A,mackie 24/8buss JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-03-2004 12:21 AM
patching a mic preamp to 001 dmaxj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-21-2003 12:54 AM
